R4041H Suddenly Dead
   / R4041H Suddenly Dead #1
dejo
LS 4041H
Hey All, My LS ran fine today. Went back to start it - it clicked (relay sound) and nothing. No horn or four ways...dead. Battery tests fine. Main 50amp fuse tests fine. All other fuses fine. After about 5 minutes when turning the key the same relay sounding click happens...but no power to the horn or other accessories...completely dead...except for the resetting of some relay in the steering column which then does make a soft click after 5 minutes. Anyone have this issue or have ideas on resolution?
THANKS!!
Gene
   / R4041H Suddenly Dead #2
Possibly one of the safety switches? Make sure it’s in neutral, pto off, etc.
   / R4041H Suddenly Dead #3
Check battery positive to frame ground (something other than batt negative) . Could be a bad frame ground.
   / R4041H Suddenly Dead #4
If it tests well at the battery, check the ground cable like mentioned above. Also check the hot cable for internal corrosion. I wound up having to replace both cables and replacing the 100 amp main fuse due to corrosion and excess resistance. My battery tested at 12.87 volts, but 5 volts at the main fuse panel. Use boat or milspec battery terminals and 2/0 welding cable with closed copper lugs and heat shrink.
Kubota 24in Quick Attach Compact Excavator Tooth Bucket (A51039)
Kubota 24in Quick...
2015 DODGE RAM...
2017 Schulte FX107 84in Rotary Cutter Attachment (A50322)
2017 Schulte FX107...
2023 PJ 49FT Gooseneck Trailer - 35+5, Mega Ramps, 30,000 GVW, Electric Brakes (A51039)
2023 PJ 49FT...
2016 JLG 3248RS 32ft Electric Scissor Lift (A50322)
2016 JLG 3248RS...
2006 Kobelco SK210LC Hydraulic Excavator (A49461)
2006 Kobelco...
