R4041/XR4040 Engine/PTO HP differential
   / R4041/XR4040 Engine/PTO HP differential #1
nova3930
North Alabama
TYM T494
I'm investigating the LS tractors as an option to maintain 16 acres I'm currently building a house on. In the course of comparing tractors I've noticed something odd in the specs.
I get that the primary difference in the R series and XR series is the emissions standards and different engines required to meet those standards.
When comparing shuttle to shuttle, the R4041 has an engine to PTO HP drop of 6HP whereas the XR4040 has a HP drop of 7.6HP. That's the difference between a 14.6% drop and a 19% drop respectively. As an engineer I can speculate as to transmission, PTO or quite simply test methodology differences but I'd like to know for sure.
I've noticed a similar differential with the R3039 and the XR3037 as well although reversed with the R series having higher losses.
Does anybody know what's going on with the specs?
   / R4041/XR4040 Engine/PTO HP differential #2
Noticed the same thing myself but I don't know the true answer I always assumed it was just the different engine being all clogged up with stuff. I think they still use the same transmission as before with a different engine pushing it, but I could also be wrong on that. Guess I'm not to much help!
   / R4041/XR4040 Engine/PTO HP differential #3
I think the difference is in the power curves and where each number is measured. Engine HP is taken as max HP produced by the motor up to its max operating RPM. PTO HP is taken at whatever RPM setting provides 540rpm to the PTO, that may or may not be the same as the max enginer HP RPM. That make sense?
The engine HP drop is easily explained by the different engine. That would even be explained by more emissions controls or different tuning if they used the same engine.
If they used the same transmission/PTO setup then either the absolute HP drop or the percentage drop (my $ would be on percentage) should be the same assuming consistent measurement methodology.
   / R4041/XR4040 Engine/PTO HP differential #5
Hay your the engineer I'm just a dumb electrician, yea what you said.:D
Yeah, hadn't considered different engine power curves. The R engine could easily have a "fatter" power curve putting out more power at the appropriate RPM for PTO operation. That's a very probable explanation I think...
One thing I've learned in my short career as an engineer, occupation/education and intelligence are two totally different things. The number of idiots out there with engineering degrees is astounding. :p
   / R4041/XR4040 Engine/PTO HP differential #8
I very good friend of mine also an engineer (structural) is classified as a genius, but there is no way I would allow him to screw in a light bulb! :thumbdown:
Believe me, I know what you mean. I'm thankful everyday I had a father and two grandfathers that taught me
1. common sense and
2. practical hands on skills
Having actually done things with my hands helps me realize when other engineers want to do stupid crapola lol
   / R4041/XR4040 Engine/PTO HP differential #10
Not exactly. The engine HP rating is at "rated speed" which may be below the maximum RPM the engine can turn. The two are usually pretty close, but not always identical.
I'm wondering if the difference between the 4041 and 4040 is due to the larger displacement engine in the 4041, which could mean it has a flatter power curve...something along those lines.
Skid Steer 59in Vibratory Roller (New/Unused) (A59225)
Skid Steer 59in...
2017 International WorkStar 7500 Aquatech B-15 Combination Sewer Jetter Vacuum Truck (A56858)
2017 International...
2010 Club Car Electric Cart (A56859)
2010 Club Car...
24220 (A56859)
24220 (A56859)
2022 DODGE RAM 2500 SERVICE TRUCK (A58214)
2022 DODGE RAM...
2019 Ford Explorer (A55788)
2019 Ford Explorer...
