R4041 good price?
   / R4041 good price? #31
With my HST I'm frequently only running 1,500rpm or a bit less. The manual says 1,500+ for work...probably because lugging an engine is bad for it....high load, low oil pressure.
True that lugging is not good, but the main reason to run HST engines at higher RPM is to assure adequate hydraulic pressure from the charge pump to the HST.
   / R4041 good price? #32
the more i read on this price topic makes me feel good about the deal i got. 2012 4140for 17.2
said he lost money on the deal but wanted to move it, case of being at the right place at the right time
shuttle, with the field work i do shuttle works great but hydro has its place for quick and easy operation
2022 INTERNATIONAL MV607 (A58214)
2022 INTERNATIONAL...
LOT: Coolant Pressure Tester, Fuel Pressure Tester, Amp Tester (A59076)
LOT: Coolant...
2019 MACK PINNACLE (A55745)
2019 MACK PINNACLE...
2014 FREIGHTLINER CASCADIA (A58214)
2014 FREIGHTLINER...
2013 KENWORTH T680 TRI AXLE SLEEPER TRUCK (A58018)
2013 KENWORTH T680...
(APPROX. 20) 4' X 8' X 3/8" SHEETING (A52706)
(APPROX. 20) 4' X...
