R4 steer tire options
/ R4 steer tire options #1
KennedyDiesel
Central WI
I have the larger R4 tires which are Galaxy Marathoner. They've been good to me, but I destroyed a steer tire when I unknowingly ran it low and cut the sidewall. We booted and tubed it and it has lasted about 3 more years, but now it is shot.
So has anybody tried anthing different? Particulary in a wider size for better floatation. The 27-8.50-15's are just a bit narrow for any loader work on soft ground.
I doubt I have the clearance without spacers, but it doesn't hurt to ask...
/ R4 steer tire options #2
flip the wheels side to side and you have plenty of clearance....
i always run mine on the wide setting
I think looked at this a while back, but forget why I ruled it out. Do you recall how much it changed the front track width?
/ R4 steer tire options #4
Firestone lists a 27-10.5-15 R4 for skid steers. They would give you about 2" more width. Designed to go on a 8" wide wheel, I am guessing you have 6" or 7" wheels. They would also have more load capacity than your current tires. I would check with the JD dealer for wheels, parts may be able to find them from something else, maybe a JD skid steer? :thumbsup:
/ R4 steer tire options #5
It is a lot can not remember exactly, want to say some where around 4 inches per side. I flipped them on my 3720 but I also have 6" spacers on the back.
I took a look and there is a lot of dish on the wheels so flipping would make quite a difference. I had to make a decision so I ordered a pair of Titan Trac Loader in the same size. They are rated to carry 2480# I believe where the originals were 2070#. The Titans are spec'd at 8.8" wide versus 8.4.
I've been contemplating the 27-10.50's but need a wider wheel. I'd also need to shift all of the added weight outward.
Titan also has an 8 ply unit that is stiffer yet at 2800#+ but loses so much lug depth with the beefy shoulders.
The Titan Trac Loader tires measure a full 1/2" wider which should help with floatation a bit. The lugs are a bit more open which should help with grip a bit.
Hindsight being 20/20 I probably should have gone with the 10.5's as I think they would clear OK with the wheels set in, but technically I need wider wheels so I'm content with my choice for now. The big thing is that they are installed and ready for action...
/ R4 steer tire options #8
Glad you came up with a solution! Let's see how they look...
AKfish
2019 Freightliner M2 106 AWD Altec DM47BTR Insulated Digger Derrick Truck (A60460)
2019 Freightliner...
2019 KUBOTA SVL95-2S SKID STEER (A64279)
2019 KUBOTA...
2012 International Prostar (A63118)
2012 International...
Rake Master CR-72G (A64119)
Rake Master CR-72G...
Doyle Conveyer with Honda Engine (A63688)
Doyle Conveyer...
2017 International 4300 Box Truck (A62613)
2017 International...
