R4 steer tire options
   / R4 steer tire options #1
KennedyDiesel
Veteran Member
Central WI
I have the larger R4 tires which are Galaxy Marathoner. They've been good to me, but I destroyed a steer tire when I unknowingly ran it low and cut the sidewall. We booted and tubed it and it has lasted about 3 more years, but now it is shot.
So has anybody tried anthing different? Particulary in a wider size for better floatation. The 27-8.50-15's are just a bit narrow for any loader work on soft ground.
I doubt I have the clearance without spacers, but it doesn't hurt to ask...
   / R4 steer tire options #2
flip the wheels side to side and you have plenty of clearance....
i always run mine on the wide setting
I think looked at this a while back, but forget why I ruled it out. Do you recall how much it changed the front track width?
   / R4 steer tire options #4
Firestone lists a 27-10.5-15 R4 for skid steers. They would give you about 2" more width. Designed to go on a 8" wide wheel, I am guessing you have 6" or 7" wheels. They would also have more load capacity than your current tires. I would check with the JD dealer for wheels, parts may be able to find them from something else, maybe a JD skid steer? :thumbsup:
   / R4 steer tire options #5
It is a lot can not remember exactly, want to say some where around 4 inches per side. I flipped them on my 3720 but I also have 6" spacers on the back.
I took a look and there is a lot of dish on the wheels so flipping would make quite a difference. I had to make a decision so I ordered a pair of Titan Trac Loader in the same size. They are rated to carry 2480# I believe where the originals were 2070#. The Titans are spec'd at 8.8" wide versus 8.4.
I've been contemplating the 27-10.50's but need a wider wheel. I'd also need to shift all of the added weight outward.
Titan also has an 8 ply unit that is stiffer yet at 2800#+ but loses so much lug depth with the beefy shoulders.
The Titan Trac Loader tires measure a full 1/2" wider which should help with floatation a bit. The lugs are a bit more open which should help with grip a bit.
Hindsight being 20/20 I probably should have gone with the 10.5's as I think they would clear OK with the wheels set in, but technically I need wider wheels so I'm content with my choice for now. The big thing is that they are installed and ready for action...
   / R4 steer tire options #8
Glad you came up with a solution! Let's see how they look...
AKfish
2011 MAGNUM PRODUCTS LIGHT PLANT/TANK TRAILER (A53843)
2011 MAGNUM...
UNUSED WOLVERINE CB-11-750F HYD CONCRETE BREAKER (A54757)
UNUSED WOLVERINE...
2015 CATERPILLAR CT660 TANDEM AXLE DUMP TRUCK (A54313)
2015 CATERPILLAR...
JOHN DEERE 2350 TRACTOR (A54756)
JOHN DEERE 2350...
Caterpillar Loader Quick Coupler (A55218)
Caterpillar Loader...
UNUSED LANDHONOR PHA-16-2C HYD 3PT HITCH MOUNT (A54757)
UNUSED LANDHONOR...
