R4 Mowing Tears Turf
   / R4 Mowing Tears Turf #21
Thanks, Joe......that's easy enough that even I can do it......and a cheap laser level I do have. If it isn't too cold the next few days, I'll do it and report the result. Boy, I hope they check "okay".
My NH owner's manual has instructions for front wheel alignment--which I haven't read in a long time. I should because my tie rod is beginning to look like a snake. :eek:
Maybe your manual does too. I know it's not the first thing thought of for tractors.
Well, after looking in the owner's manual and looking at the front end parts (in my pajamas/flashlight:laughing:), I don't see anything that is "adjustable" anyway....hum-m-m ....dang....it's cold out there.
   / R4 Mowing Tears Turf #23
Sorry I sent you on a goose chase.
   / R4 Mowing Tears Turf #24
I'be dowenright astonished if the toe-in wasn't adjustable. Probably the only adjustment there is, but it's there.
Okay, y'all....I'm either blinder than a bat, dumber than an ox or there isn't anything "adjustable" on the B2620 front end. The tie rod is a solid bar and the front axle/wheel parts are all solid bolted together. It was a nice day to really get under there and look it over. Any experts out there on this model? ....just curious about it all.
   / R4 Mowing Tears Turf #26
Sounds like our B7500... Need to adjust the toe in on it, but there doesn't seem to be any way to do that.
Aaron Z
2016 DORSEY FC48 48FT FLATBED TRAILER (A58018)
2016 DORSEY FC48...
Mohawk 12,000lb Two-Post Electric Auto Lift (A55851)
Mohawk 12,000lb...
1992 DFI PULL SPREADER (A57192)
1992 DFI PULL...
VINTAGE JOHNSON OUTBOARD MOTOR (A58374)
VINTAGE JOHNSON...
Gas Pump Artwork (A55758)
Gas Pump Artwork...
Poly Bristle Sweep, 78" x 8" (A59076)
Poly Bristle...
