R4 Mowing Tears Turf
   / R4 Mowing Tears Turf #11
Nothing says R-3's can't be found that match the dimensions of the R-4's close enough to work well. In fact, many common sizes of CUT fronts are available in both tread styles. It's not at all uncommon to see CUT's equipped with FEL to have turf rears and R-4 fronts due to the increased load capacity of the R4 as compared to R-3's.
That kind of defeats the purpose of tearing up the grass with the front tires doesn't it. Rear tires don't do much damage to grass when turning, just the fronts and if proper care is done to slow down, avoid super sharp turns and stay off the grass if the ground is wet, will pretty much eliminate the damage. If one wants a golf course cut and groom, get a machine made specifically for mowing and use the tractor for pulling, loading and other tractor type activities.
   / R4 Mowing Tears Turf #12
Is that commonly the experience? I've never used a tractor for lawn mowing, but the area in front of my equipment shed is turf, and both there and when bushhogging my field I find all the damage to the turf from sharp turns is done by by the rears.
Terry
Well, my place ain't no golf course, but tight turns are an issue around the house where there are a lot of trees. The straight aways in the open fields are not a problem. Having a dedicated mowing machine is not in my budget and I doubt that new turf tires for the front are either....but I have considered that turfs on the front could help my situation on down the road. In the shady damp areas the turf itself is rather shallow as Chim alluded to. Cheers.
   / R4 Mowing Tears Turf #14
My experience with R3s on the 4010 and now R4s on this 1025 is that the R3s tear up the turf more because they grip better in front during a turn. The R4s, because of their design, tend to skid sideways when the tires are turned past a certain point.
Ralph
   / R4 Mowing Tears Turf #15
....If one wants a golf course cut and groom, get a machine made specifically for mowing and use the tractor for pulling, loading and other tractor type activities.
That's the rub, isn't it? Most CUTs are general purpose machines; Jacks-of-all-trades, masters of none. I went with a 3000+ pound machine because my primary use was to push, pull, dig, and plow. The only mowing I'm likely to do is rough mowing the weeds and saplings on the sides of the drive, or on the trails through the woods; not manicuring a putting green. (God, can you imagine using AG tires on a putting green? The green alone would be a par 6!
   / R4 Mowing Tears Turf #16
If you take time to understand what I posted, you would realize that I was using the R4 front/ R3 rear combination FOR THE REASON I STATED as an example of how the opposite configuration could be used just as successfully to suit the OP's purposes. I didn't expect my post to be so hard to grasp..............
   / R4 Mowing Tears Turf #17
As for front end alignment, I can't say for sure. ...
If you have a cheap laser level, it wouldn't be hard to check.
Park 20 feet or so from a wall or garage door, with the tractor facing the door, and square up the wheels as best you can. Then hold the level against the rim, with the laser shining on the door. Mark on the door where the laser hits it. Repeat on the other side. Measure the distance between the two places the laser hit the door. How does that compare to the front wheelbase?
That wouldn't be good enough for a car. But if you have an alignment problem bad enough to hurt the turf it would show it.
Thanks, Joe......that's easy enough that even I can do it......and a cheap laser level I do have. If it isn't too cold the next few days, I'll do it and report the result. Boy, I hope they check "okay".
   / R4 Mowing Tears Turf #19
I have a B2920 with fluid filled turfs. In 4wd they tear up the lawn at any speed in a turn, in 2wd as long as I'm not flying in high gear or something I've never had any issue (as long as it isn't muddy). My lawn is particularly sensitive as it's loam over clay, so any water and the top layer is mush. I don't mow, but driving around with the FEL on only I'm fine and never have an issue in 2wd. With more weight like the BH or a heavy implement I have to be more careful. If you mow with turfs and a MMM with no FEL I'd say that you'd be totally fine. There's no much that the R4's will do that turfs won't (except wear faster on paved surfaces), so you probably won't be losing much by switching, I'd just try to sell the R4's.
:2cents:
Seems to me that could happen when the hog is raised during a turn because the weight of the hog would make the rear heavy, whilst the front would be light. But I've never had a bushog and consider myself an amateur in tractor stuff.
Terry
1202 (A58374)
1202 (A58374)
New Wolverine 72in Skid Steer Brush Cutter (A59000)
New Wolverine 72in...
2019 PJ  40FT GOOSENECK TRAILER (A58214)
2019 PJ 40FT...
2001 Bobcat 873 Compact Track Loader Skid Steer (A56857)
2001 Bobcat 873...
LOT: (200 approx.) Gallons of Chevron Delo TorqForce SAE 10W Hydraulic Oil (A59076)
LOT: (200 approx.)...
SAND ALL SANDBLAST POT & RESPIRATOR (A52708)
SAND ALL SANDBLAST...
