R4 front tires, Turf rear
   / R4 front tires, Turf rear
:confused2: So ... Youre giving up on the conversion to R4 fronts? It should be easy enuf to get rolling circumference specs from tire mfgs to compare with what you have now. If youre doing loader work the R4s would be a plus.
larry
With all the discussion about mfg spec mis-matches, I'm afraid if I convert to R4 fronts I'll mess up the front to rear tire ratio if I don't also change the rear turfs.
   / R4 front tires, Turf rear #22
I couldn't find the story, it was a long time ago. I remember reading though that tire size was critical with constuction and ag equipment that was 4wd. The story was in construction equipment mag. They put together a study with tire mfg and users of tires. I don't remember the % of size difference they came up with, but it was very important to keep tires on the same axle close and also from front to back even on backhoes and tractors. If they didn't it put a lot of stress on parts and would lead to breakage. I remember one company with there loaders about doubled axle and transmission life when they began replacing tires based on wear. If they had to replace 1 tire, they would measure the rest of the tires and if they were too far from a new tire, either both on the axle or even all 4 would be replaced. The air pressure was also important to try and keep things even all the way around.
   / R4 front tires, Turf rear #23
open up the phone book and look up "auto tires" and just start calling 100 plus places that sell regular car/truck tires. it will take some times. but after so many calls someone more likely knows a telephone number or name of a place. and you just need to be ready to jot the name / phone number down quickly.
if you do a internet search through some phonebook website. look up agriculature or ag tires, or farm or something like that. and lookup for places a couple hours away. prices can vary widely.
if you are wanting tires installed for you onto the rims. it may be easier for a given place to just come out and pull off old tires and put new tires on, right at your place. there is a service fee for doing this, and price can vary widely. if you are wanting rear tires filled with a liquid. then it would be extra fee of course, but most likely who ever comes out for service to do tire swapping, already has a setup in there truck to fill the rear tires up with a fluid.
was told for large tires, they prefer to have tire still mounted to the tractor. so they can use the tractor itself, to hold the rim, while they pop the old tire off / put new tire on. vs trying to jack around with a tire laying on the ground.
there are name brand tires, and off name brand tires. some dealers will only deal in certain brand/s of tires. and for some name brand tires cost is 2x compared to off brand tire manufactures. what the difference is i do not have a clue.
again just start callling 100 plus places that sell regular car/truck tires in phone book, to find the local places that deal with tractor tires. and then do a internet search for a couple hours away.
for me, i found a place i want to say 1.5 hours away from me, and including service fee for coming out to me for putting on new tires, plus miles, and 2 tires, with tubes, and got a higher ply rating, it was cheaper by a couple hundred bucks vs someone locally.
my question is what caused the front tires to wear? are you running on hard dry dirt or pavement / concrete a lot? with 4WD engaged? is tractor/tires that old and just over time have gotten that way?
check and find out cost, for replacement for all 4 tires. different tire brands may have different outside diameter contact the various tire dealers near you. and see what they recommend for the given brand and size of tire that will fit your tractor.
what do you use the tractor primarily for? and other misc tasks?
Kubota L3130 (A53317)
2018 Ford F-150 4x4 Crew Cab Pickup Truck (A56858)
2018 Ford F-150...
2007 Honda CR-V SUV (A56859)
2007 Honda CR-V...
2016 Ford Explorer AWD SUV (A55853)
2016 Ford Explorer...
2014 HYUNDAI 53FT DRY VAN TRAILER (A57880)
2014 HYUNDAI 53FT...
2020 FREIGHTLINER CASCADIA SLEEPER TRUCK (A57880)
2020 FREIGHTLINER...
