Mowing R3039 PTO Pin Hole
   / R3039 PTO Pin Hole #1
altamaha
Jesup, GA
LS R3039 DB 990
Been using my 3039 for pulling disc harrows and cleaning up the remains from the spring garden, and using the ratchet rake for cleaning some brush trees out of my pines.
Today I decided to run the bushhog a little. My old hog has long since lost the little push pin that connects the yoke to the shaft. I always use a pin through the yoke and shaft. Imagine my surprise when I discovered my shaft does not have a hole through it.
Are all of the shafts solid, or do I have one that was missed during QA from LS?:confused2:
OK... Thanks. Guess it is time to replace the shaft on my hog. Not sure if I can just buy a replacement pushpin setup.
2019 Ford F-350 4x4 Crew Cab Auto Crane EHC-4 4,000lb 2 Ton Mechanics Crane Service Truck (A50323)
2019 Ford F-350...
2016 Kenworth T880 T/A Vactor 2112P-16 Combination Sewer Jetter Vacuum Truck (A50323)
2016 Kenworth T880...
2021 Delta Redirective Crash Cushion 75000 (A51692)
2021 Delta...
2022 Ford Maverick Crew Cab AWD Pickup Truck (A50323)
2022 Ford Maverick...
