Tires R1 Titan tires
   / R1 Titan tires #1
mrf_la
La.
JD 790 / 2005
I almost don't believe it after only 26 hours of use, but my left rear tire developed a slow leak. Found small quarter inch cut in lug. On the "side" of lug not bottom. Should I pay the dealer to pick the tractor up as I have no trailer or take the wheel off and carry it in? Can a hole in the lug be fixed?
How much do people pay for a flat repair under warranty on JD 790?
   / R1 Titan tires #2
I'll go out on a limb here, I think the cost is the same with or without warranty. Getting a flat is normal wear and tear. That being said, try and plug it, it may not work on a sidewall but it's worth a try. Maybe it could be patched from the inside, calling different tire dealers will get you an average cost. Is the tire filled?
   / R1 Titan tires #3
</font><font color="blue" class="small">( How much do people pay for a flat repair under warranty on JD 790? )</font>
Flat repair under warranty? /forums/images/graemlins/confused.gif I doubt it
   / R1 Titan tires #4
Assume that this IS NOT a warranty item. But ask your dealer if anything can be done about it. There may be a way he can help you. Sometimes you can get exceptional service!
But maybe you are in a situation where you had better think about foam filled tires quick. If this is actually 'normal' use, you probably can't afford NOT to have them filled!
   / R1 Titan tires #5
NO biggee. They can put a boot in it to reinforce the sidewall or anyother part of the tire. I have a left front that has to go in soon. Has a 1in hernia on the side. Can see the tube.
(9) ROLLS OF 5' - 10 GAUGE CONCRETE WIRE (A54757)
(9) ROLLS OF 5' -...
12 X 20 CAR PORT (A58214)
12 X 20 CAR PORT...
2018 KENWORTH T800 HOTOILER (A58214)
2018 KENWORTH T800...
2010 MULTIQUIP 25KW GENERATOR (A55745)
2010 MULTIQUIP...
2004 Freightliner FL60 Ambulance (A56858)
2004 Freightliner...
NEW Fork Extensions (A59000)
NEW Fork...
