R/F WHEEL LOCK UP
   / R/F WHEEL LOCK UP #1
CHUCKWAGON
TENNESSEE
FARM PRO 30 HP 4X4
I have a 2430 4 x 4 farm pro. My right front wheel will lock up from time to time. When I notice it sliding (locked) I back up a few feet and it seems to be ok. Any suggestions on what's causing this problem. I'm confused /forums/images/graemlins/confused.gif My tractor is just coming on 250 hrs. Thank you Chuck..
   / R/F WHEEL LOCK UP #2
Chuckwagon,
Are you in 4x4 when this happens? Eitherway, I think I'd take a look at it before more damage occures.
There's a lot of folks here that can help determine what's going on and get it back together.
   / R/F WHEEL LOCK UP #3
You mentioned that it only happens on occasion, and you have a lot of hours on it.
This seems like a warning sign that something needs attention. With that many hours something may be wearing out, There are some very experienced folks here to help in case a dis-assembly/inspection is in order.
When was the last time Front Differential was drained and Lube changed. Even if done recently I would drain it again into a pan that will allow inspection of old fluid. Check to see if it's torally contaminated with glitter (Metal Grindings) as that would mean something needs immediate attention. Check for white paste in the old oil as this could be a sign of water and may lead to rusting parts. If not too contaminated with metal grindings would put fresh lube in there and see how things work. You may get lucky!
Tim
   / R/F WHEEL LOCK UP
It happens when I'm either in two or four wheel drive. The first time is when I was haying my fields last yr, then every once in a while there after. ( maybe 4 times all together) I'm not sure if any one else has had this type of problem. I'm just not sure what's causing it. Other than pulling that wheel assembly apart to find out. Another thing to keep me busy. /forums/images/graemlins/grin.gif
I will be giving my tractor a major service before the work season starts up this yr. Not quite 250 hours on it.
   / R/F WHEEL LOCK UP #5
Drain and remove the diff cover. It might just be a chunk of something that's jamming the drive gears occasionally. Like items 12 and 13 in THIS PICTURE. If not, you might have to open the right side. Drain is below the hub. Junk may be jamming items 29 or 47 in THIS PICTURE.
//greg//
   / R/F WHEEL LOCK UP #6
Guess I'll be the bad guy here and say it sounds like one of the miter gears has a borken tooth. When it gets out of sync the teeth lockup on each other. You'd have to tear it down and have it look at it anyway as this is not a good sign.
   / R/F WHEEL LOCK UP #7
I have to agree with above posts. It does not sound good. Maybe, just maybe if its a piece of "something" wedging between the gears it might not be costly. If you continue using it the way its acting then more damage could occur especially if you force it.
I'd avoid using it until I investigated it more. Its not too big a job to do.
Keep us informed.
Harry
   / R/F WHEEL LOCK UP #8
Since it does not do it all the time,I think that something is loose in there,we have seem one of the two bolts that hold the driving gear on loose,I would take it down sooner than later before it mess's up more parts
Tommy
Affordable Tractor Sales
   / R/F WHEEL LOCK UP #9
Mr.Fixit:
If it's worn out at 250 hours, it must be made of swiss cheese. 250 hours isn't even broken in.
2012 International 4300 Vacuum Excavation 7.6L Diesel Truck w/Vanair Vacuum (A51691)
2012 International...
2014 GMC Sierra Pickup Truck (A50323)
2014 GMC Sierra...
Adams 5 T Spreader (A53473)
Adams 5 T Spreader...
2012 Ford Fusion SE Sedan (A51694)
2012 Ford Fusion...
2016 Arising 8.520VTRW 22ft T/A Enclosed Cargo Trailer (A51694)
2016 Arising...
2018 John Deere HPX615E 4x4 Utility Cart (A51691)
2018 John Deere...
