Quickie homebuilt skidshoes for Landpride RB
   / Quickie homebuilt skidshoes for Landpride RB #1
Toolguy
Platinum Member
West Michigan
B3030
I made these one day when the snow first started falling this winter. I haven't painted them yet but I will in the spring when it warms up. Built them mostly from scrap pieces I had laying around including and old receiver hitch. That is what provided the 2" square tube and the metal for the skids. The first picture is of the RB on my B3030.
Rear veiw.
Closeup.
Other side.
Top. I originally made these for a RB1560 blade. They were just bolted onto the cutting edge bolts. When I traded up for a RB1572 I found the bolt pattern on the blade was a little different. I could only use one bolt so I just welded them in place. For height adjustment I drilled 7/16" holes in the square tubing in several different places. Whn I switched them over to the new blade I found that the shoes were about 1/16" too low to scrape my concrete driveway clean. To adjust the height I swapped the 7/16" pins for 5/16" bolts. It works perfect that way and as the shoes wear I will just go to 3/8" bolts and finally back to the 7/16" pins. by then I'll need to replace the shoes.
   / Quickie homebuilt skidshoes for Landpride RB #6
Thanks for the pictures. /forums/images/graemlins/cool.gif
   / Quickie homebuilt skidshoes for Landpride RB #7
3 years later... I was looking at your homebuilt skidshoe pictures and wondered how well they work at an angle when your blade is set a 30°?
I am considering the purchase of a LP RB2572 similar to yours although a bit heavier to match the weight of my 54" Kubota box blade/scraper. Since I have a gravel driveway and my need is snow removal I am also considering a pair of hand fabed 30° swing mount tires mounted to the back of the blade.
2014 PJ TRAILER 40' TANDEM AXLE GOOSENECK (A52472)
2014 PJ TRAILER...
2002 John Deere 5220 (A50120)
2002 John Deere...
2008 JACK  130BBL (A52472)
2008 JACK 130BBL...
2018 INTERNATIONAL 4300 26FT NON CDL BOX TRUCK (A52576)
2018 INTERNATIONAL...
1986 John Deere 6359D (A50121)
1986 John Deere...
Michelin CARGOXBIB High Floatation Tires (SET OF 4) (A52748)
Michelin CARGOXBIB...
