Quick
/ Quick #1
marrt
Platinum Member
Northern VA
Power Trac 1845 and 425
Edit: I accidentally hit return before I finished typing the Title ("Quick Attach Bolt On"). Apparently, there's no way to edit titles.
I have an extra Quick Attach plate and I want to bolt on a trailer receiver hitch. However, I’m concerned that the bolt heads will stick out too far in the back to allow the plate to fit properly on my tractor. Has anyone tried to bolt something to a quick attached plate? If so, what type of bolts did you use (so that the heads where flush enough to allow the plate to work proberly). Any pictures? Thanks.
/ Quick #2
use counter sunk bolt heads,nuts on the hitch side.like to weld on better...jim
/ Quick #3
if i remember correctly, i had to counter sink the holes on the quick attach plate and used counter sink bolts or screws that had a slot in the head to tighten.
/ Quick #4
marrt, Look at my thread (Low Use Attachments) for info on bolting attachments to a quick attach plate
/ Quick #5
Some quick attach plates have predrilled counter sunk holes. Others do not. I made some of my own on one that did not have them. I used 1/4 20 bolts. I later felt this was too weak and about that time I got a welder and started welding items on.
/ Quick #6
It'll cost probably less to take it to a welding place and have it welded on the plate than you'll have in bolts (grade 8) and time. Weld it unless you want to undo it to use the plate for something else. You can always use a grinder to remove it from the plate. JMO
/ Quick #7
Bring it by my house and I will weld it for you. I live a little west of Richmond Va. I made my own.
/ Quick
Thanks for the offer Bob but I live a bit too far from Richmond.
FYI, I want to bolt this on, rather than weld, because I intend to ultimately use the attach plate for another project.
I think I will try some bolts like the attached image. Should work I think with a little counter sink.
FORD 8530 TRACTOR (A58375)
FORD 8530 TRACTOR...
Adams Weight Hopper (A63688)
Adams Weight...
3pt 20' Cultivator (A64119)
3pt 20' Cultivator...
2016 Jeep Compass SUV (A61574)
2016 Jeep Compass...
2014 Land Rover LR2 AWD SUV (A61574)
2014 Land Rover...
2005 Peterbilt 379 Ext. Day Cab (A62613)
2005 Peterbilt 379...
