Quick Spade
   / Quick Spade
That's very cool, I've never seen one like that. Regular ratchet binders like I already have won't do the job?
   / Quick Spade #12
I have had the spade for about 10 years. I think it is one of those things that look handier than it is. My new tractor has a different bucket and it seems to flex quite a bit under hard use. My bucket has bent some. I plan to weld mine on a quick attach plate to keep it from happening again.
   / Quick Spade
I might put this in the category of something I'll purchase when I have "cash to burn" out of curiosity, or when I have a specific need for it once I start removing the shrubs and trees around our pool. The landscaping was already there and it's not ideally exactly what we want.
You mention welding yours to a QA plate. That's sort of an idea I have in mind for a spade bucket with the AI2 quick attach plate. Or I guess even welding this thing to it, which would be lighter and cheaper. It wouldn't have near the reach then, though.
   / Quick Spade
Just ordered one. We have some older boxwoods around our pool we want to transplant to the house, no way I'm digging them up by hand if I don't have to. So hopefully this will help. Should be here Friday. Will update!
I wish I could get some shorter forks specifically for stuff like this, to put less leverage against the loader. I keep meaning to message Redline or Tony at AI2 to see if I can buy two more fork tines to cut down.
Anyway I have soft sand. If I'm careful hopefully all will be well.
   / Quick Spade #16
I made one to attach on the bucket, and have used it for years without damage to the bucket. I don't have soil here I have rocks with a small amount of clay around them. I have dug many ditches etc with this home made tool I have about $6 in.
You can read about it my trials and tribulations on getting it built right in the link below. But I prevailed. And it is a useful tool.
   / Quick Spade #17
I wish I could get some shorter forks specifically for stuff like this, to put less leverage against the loader. I keep meaning to message Redline or Tony at AI2 to see if I can buy two more forks to cut down.
I think you will be fine.
   / Quick Spade
I have read your thread. I like that a lot! You made it simple, and effective.
I wanted the one that can slip on the forks OR clamp on to the bucket, but that was $380 vs $180. So I just got the one for forks, and I'd like to try my hand some day at modifying it to be able to clamp onto my bucket also.
   / Quick Spade #19
I picked one up to do some ditch work. It performed reasonably well on the first outing.
My logic is that when ditching on an incline, I should be able to keep the spade in a steady position should allow the ditch depth to follow the contour.
It seems to work...just need to use it more to become proficient.
The spade itself is a beast...very well built, and actually larger than I expected.
Pleasantly surprised...
   / Quick Spade
I thank y'all. That's about all the "cheap" implements I can think of to get. It's all expensive stuff from here on!
Man Basket Forklift Attachment (A55851)
Man Basket...
Honda EM3500S Portable Gasoline Generator (A55851)
Honda EM3500S...
2013 BMW X5 xDrive50i AWD SUV (A56859)
2013 BMW X5...
UNUSED FUTURE CAT 305 24" EXCAVATOR BUCKET (A57193)
UNUSED FUTURE CAT...
LMC G500-500A 72" Grapple (A56469)
LMC G500-500A 72"...
2021 Deere 333G (A53317)
2021 Deere 333G...
