QUICK ROTARY CUTTER ADVICE NEEDED
   / QUICK ROTARY CUTTER ADVICE NEEDED #11
I think it all depends on what type of cut people expect from a rotary cutter. I am very hard on my cutter as I am clearing back 12-15' tall red brush. I will go from cutting brush to cutting field and not worry about how the cut looks as all I need to do is knock the stuff down. I do know some people want their cutters to mow like a finish mower and they sharpen blades a lot. I sharpen the blades on my woods when it needs it which is about once every couple years and that is because of the rocks that I keep finding.
   / QUICK ROTARY CUTTER ADVICE NEEDED #12
Before I bought my finish mower, I used my 6ft medium duty Land Pride cutter to do all my mowing with. Most of the heavy, rough stuff was cut down the first year I had it, so since then, it's mostly maintenance.
That first year was really rough on it, and I burned out the gear box. I had a three year warrentee on it, so I told my dealer that it was making a gawd aweful noise. He said to keep using it since I was getting a new gear box, and when it came in, he'd change it for me. Which is what I did.
Since then, I used it for mowing bahia and bermuda grass. Sometimes it was a foot tall or taller and that would really bog down my 35hp tractor if I went too fast. It also wears out the blades.
I re-sharpened them one year and had to replace them the other year. In four years, I've put two sets of new blades on it. I don't know if the metal is just softer then other blades, or if my grass is just more abrassive, but the blades on my mower wear out. They come new at about 3 inches wide, but after two years, there's barely an inch of metal left on them.
Now that I have a finish mower, I just used my rotary mower one time this year to mow the really thick stuff that grew on my spillway. It was too wet to mow when it was flowing, and it got pretty bad. I cut it down real easy with the rotary cutter, and have maintained it with the finish mower.
My blades require a 1 11/16 socket and 450ft pounds to remove and tighten them. I bought a bigger impact wrench and paid $45 for the socket just to change my blades. The first time was a real nightmare, but after that I can do it in under an hour pretty easily.
If it was me, I'd buy the cheaper one considering they are so similar.
Eddie
   / QUICK ROTARY CUTTER ADVICE NEEDED #13
I have the Woods BB60X and am very happy. As stated above, the 1 1/2 inch rated capacity seems conservative. If I can run it over, the RC will do it's job. This is my first and only cutter, but I do have a little seat time on a friends MF with a el-cheapo cutter of some sort and the Woods just blows it away. It would be my choice if I had to buy it over.
   / QUICK ROTARY CUTTER ADVICE NEEDED #14
in my opinion - the woods is a step above the rest. it's build like an army tank and worth the extra 200 bucks.
J
   / QUICK ROTARY CUTTER ADVICE NEEDED #15
I second the Wodds I have the BB60 and as stated that thing is a TANK...
I have cut 4 AC of 3"+ popular saplings down with that thing and while is slow going it is a BEAST...
Good luck
   / QUICK ROTARY CUTTER ADVICE NEEDED #16
Something about this I don't understand...
Pros:
The Woods mower has a 6 year warranty, versus a 5 year.
Cons:
The Woods mower has thinner deck sheet metal.
The Woods mowers have had historical gearbox problems.
The Woods mower is $200 more than the Bush Hog.
The $200 is cheap compared to what down time and repair cost are going to be if your dealer decides that you are tearing up the gearboxes instead of them failing under warranty.By the end of the 5th year, it isn't going to matter much, unless you baby that gearbox and keep records of all the oil changes, then they pretty much have plenty of reasons to say it was user abuse, and just how do you prove that you never hit a rock with it, never cut over 1.5" material, and if you got close to something like that, you got off the tractor and measured it before you cut it with the Woods. I can just hear the service guy saying that it didn't fail due to manufacturer defect, but due to user abuse, or how about it just wore out. Hard to make a company spend their money on a 5+ year old gearbox.
I prefer to purchase a tried and proven item, that the manufacturer put the time in to make sure their product was top notch before they put them on the market, instead of a company that has had problems and simply adds another year to the warranty to make it appear that they stand behind their mowers longer. The $200 extra your paying would probably purchase an extended warranty thru some "Extended Warranty Company". I have seen them warranty other things like computers, and why would anybody want to replace a 5 year old computer when it croaked, with an exact duplicate?
I am on the Bush Hog version side of this, and I haven't even looked at either models your talking about. My opinion of these two are derived from what I have read on this forum and my observations of what they look like after 3-5 years in the commercial arena.
I think that I am gonna go ahead and get the Bush Hog brand. I bought a new 5' Squealer (SQ600-shearpin) alittle over 2 years ago and put it through he**. It is still as strong as it was when it was new (my uncle has it now). Only things I had to do were weld the tail wheel frame shaft a couple times and put a new input shaft seal in it. It got a VERY good workout when I had it. I traded him for a 5' King Kutter because the tractor I had at the time did NOT like the Squealer. But the tractor I have now, my 231 Massey Ferguson, ain't goin' no where!
I Know first hand how good the quality of Bush Hog is. So, Why should I Change?
I'm going to get the SQ172 Shear pin model (I don't like a slip clutch). It will cost me $1395 loaded on the trailer. SOUND OK??
BUT.........depending on price, I just MAY come home with a Bush Hog model 296 !!
We'll see how it goes.
THANKS to ALL OF YA',
Travis R
   / QUICK ROTARY CUTTER ADVICE NEEDED #18
Now your talking...
I got the SQ172 Squealer. $1395 loaded on the trailer. I used it for about 45 minutes this evening. I am very happy with it. I am glad that I didn't get the 296. My tractor definitely would not like it.
Thanks to all,
Travis R
   / QUICK ROTARY CUTTER ADVICE NEEDED #20
Thanks to all,
Travis R
The 296 is a huge chunk of steel!!
1993 Mono Dump Trailer (A50514)
1993 Mono Dump...
Great Plains Grain Drill (A50515)
Great Plains Grain...
2019 Ford Explorer AWD SUV (A50324)
2019 Ford Explorer...
UNUSED AGT MX15RX EXCAVATOR (A51243)
UNUSED AGT MX15RX...
UNUSED FUTURE SKID STEER MOUNTING PLATE (A51244)
UNUSED FUTURE SKID...
2008 Wilson Hopper Bottom Trailer (A50514)
2008 Wilson Hopper...
