Quick-release loader buckets
   / Quick-release loader buckets #11
I have a quick attach Kasco adapter for my L3710 and it fits tight. Some mounts are actually very tight when mouted. I have little to no wiggle room on my bucket and other attachments.
   / Quick-release loader buckets #12
I purchased a new B21 in October with the ATI quick attach and ATI bucket with bolt-on cutting edge. After a year of research, this configuration seems to be the wave of the future. This is especially true with a larger tractor -- like the L48. The universal attachment gives you a world of options. I've seen skid-loader operators use 3-4 implements and make 20-30 changes in a day. Down the road I imagine that there will be a convergence of skid-loader and tractor implements. More importantly for tractor owners, the technological dynamism seems to be coming from the skid-loader segment.
Regarding ATI - they're very innovative. The weight of the ATI quick-attach and bucket was only slightly more than the Kubota bucket alone. I have the exact numbers somewhere if you're interested. The cost of the new B21 was only $300 more with the ATI configuration. Now that was a no-brainer. With respect to their other implements, they've made 32"and 42" forks for the B21 and have been able to reduce the weight to 200 lbs. for the 2,000 lb. rated forks. That's a major technological achievement from the perspective of this small tractor owner because you can move them by hand, if necessary. The only comparable forks come from Northern - about 275 lbs for 2,000 lb. rated forks. However, ATI charges $680 for the forks while Northern's generic forks cost about $500-600.
I'm surprised that this forum has not had more discussion about the universal attachment technology. It has parallels with the PC industry because it fosters innovation on an open platform. I looked at postings from the past 18 months and found very little comment on this area. In the mid-1980s, IBM wanted you to purchase its $5,000 PC that was 1/2 design cycle behind the $2,000 generic PC that had better components. Everybody makes "generic" PCs there days. Today the major tractor makers want you to purchase their buckets and lock you into their implements. Is the quick-attachment system, a.k.a. "Bob-tach", the wave of the future?
According to my dealer, if you purchase a new L48 with a universal attachment system carrying the Kubota name, the system is made by ATI. I think that the convergence has begun.
   / Quick-release loader buckets #13
DoctorK - Quick-attach systems are definitely getting more and more popular. I'm certainly enjoying mine. One of the reasons you don't see more discussion of them here is that the vast majority of tractor owners here own tractors with FELs that have less than 1,000 lbs of total capacity (that's a supposition, not necessarily a fact), and most folks with that size tractor aren't willing to give up 10-25% of their FEL's capacity for the ability to switch implements, especially since they already have the ability to switch implements on the rear via the 3-point hitch.
Still, as the QA plates become more and more standardized and the weight penalty becomes less and less, as with ATI's new ones, as you mentioned, you'll see more and more smaller tractors going with them. They're a big advantage if you need more versatility in the capabilities of your FEL, that's for sure.
   / Quick-release loader buckets #14
DoctorK
I agree with you. Universal quick-attach is the way to go. I have been saying this in posts for the past 2 years. I have Kasco Uni-hitch and it is great. Probably very similar to ATI. I now use a bobcat hydraulic post-hole digger and forks for mine. I also made a work platform and boom for my loader. With a $75 mounting plate from bobcat, the plates can easily be welded to numerous different devices and mounted on the FEL. After hooked on, flip to levers and ready to go. Takes less than a minute to unhook and hook on. Proprietary quick-attaches like JD, almost demand you buy their stuff which again is higher in $.
The current limitation for a bob-tach type hook up is the maximum lift of about 2500 lbs which is why they don't use them on larger FEL's
   / Quick-release loader buckets #15
radman - There's now a heavy-duty version of the "Bobcat" style of QA that is rated for 6,000 pounds and is backward-compatible with the lighter duty ones, too. That's what's on my EF-5, which as a rated lift capacity of 4,850 pounds and a breakout force of 9,370 pounds.
In fact, I just got the parts for the hydraulic locking system from EarthForce, who got them from their sister company Bobcat, a few days ago. They were supposed to be installed when I got it, but they weren't ready, so I'm doing the installation myself.
   / Quick-release loader buckets #16
Come to think of it your right. Bobcat does make a small 4 wheel loader that probably uses a heavy duty QA. However, on most smaller bobcat attachments like pallet forks, hydrailic auger etc, the standard mounting plate is not heavy enough for the lifting force of your EF-5 and bigger equipment. Is the mounting plate on your bucket heavier than the standard bobcat type plate?
   / Quick-release loader buckets #17
radman - <font color=blue>Is the mounting plate on your bucket heavier than the standard bobcat type plate?</font color=blue>
I'm not sure how much difference there is, because I don't have any mounting plates that I know are "standard" duty. It's 3/8" steel, I'm pretty sure, and has a number of braces and extra pieces welded on. I'll have to look at a "standard" one next time I go past a skid steer dealer. I had several extra mounting plates ordered by my dealer to use for the Brush Brute, tiller, and soil pulverizer, and was assured they were rated for more than 5,000 pounds.
2011 MAGNUM PRODUCTS LIGHT PLANT/TANK TRAILER (A58214)
2011 MAGNUM...
2020 Ford F-250 4x4 Crew Cab Pickup Truck (A55973)
2020 Ford F-250...
Kubota U55-4 (A57148)
2004 Cat 730 Articulating Off-road Dump Truck (A59213)
2004 Cat 730...
2016 BOBCAT T550 SKID STEER (A52709)
2016 BOBCAT T550...
2021 Ford F-150 Ext Cab 4X4 Pickup Truck (A55852)
2021 Ford F-150...
