Quick question - clamp on forks to bucket
   / Quick question - clamp on forks to bucket #1
FastEddieR
Seminole County, OK
Branson 4720H
I've got a set of clamp on forks and have been using them quite a bit to move stuff...my question is about the backstop and the support chain. One or the other? Is there a not a way to use a backstop AND hook the chain to the keyhole or support the forks to keep the bucket from flexing?
   / Quick question - clamp on forks to bucket #2
I would think some bolt on hooks on top of your bucket might help. Then you could chain the backstop to the top of the bucket and reduce the stress on the cutting edge. The way the chain wraps around the bucket and connects back to the forks in your drawing offers very little support.
Of course, the best answer is dedicated forks instead of clamp on. IMO
I've got hooks welded on the top and have the forks supported using chain and load binders. Just wanting a way to put a backstop on too. Dedicated forks would be nice, but I wouldn't use them enough to justify the cost. Was thinking hook or loop welded to the back side of the backstop pocket, but not sure if it would actually be strong enough.
   / Quick question - clamp on forks to bucket #4
I have the spreader to keep the clamps at set distance apart and stop side to side twisting. Maybe you could use one of these to be your chain points ?
That's a great idea. Having the forks chained to hooks pretty much stops the twisting so I haven't really seen a need for the stabilizer bar - until now. Thanks!
   / Quick question - clamp on forks to bucket #6
that spreader bar does more good than you think.
you need a hook welded on back stop receiver or you could drill through the back stop and leave a bolt stick out for a chain to catch on.
   / Quick question - clamp on forks to bucket #7
If you use your forks alot you might like the dedicated forks.
For one the fixed forks wernt too much more than the clamp on ones.
It allows you to remove the bucket (mine is about 300lbs, maybe more) which gives you more lifting ability. The load is a lot closer to the tractor as well.
2018 HAMM H7 SMOOTH DRUM ROLLER (A51246)
2018 HAMM H7...
(1) HD 24ft Free Standing Corral Panel with 7ft Gate (A51573)
(1) HD 24ft Free...
Vermeer D16X20A Directional Drill with Mixing System and Trailer (A51573)
Vermeer D16X20A...
UNUSED RAYTREE RMLS18T 109 SPLITTER (A51248)
UNUSED RAYTREE...
1982 LeeBoy Motor Grader (A53472)
1982 LeeBoy Motor...
New Wolverine Skid Steer 3pt Hitch Quick Connect (A53002)
New Wolverine Skid...
