Quick mount
   / Quick mount #1
Svendus
Sweden
Yanmar YM2020D
Quick mount on a Vteks V2a front end loader
New custom made bracket max 500kg 1 102.31131 pounds
   / Quick mount
Be leave me
A Vtek V2K loader has 200 mm c / c dimensions of the bucket attachment
the Quick bracket we got the c / c 170 mm dimensions which result in bent shafts on tilt pistons in fully raised position of the loader
I'll tryed if I can direct piston rods and after 2 hours careful work with our small 10 ton hydraulic press we made it straight again :duh:
Here's a link to 6 photos in my Dropbox:
https://www.dropbox.com/sc/n6lin21j9wht1l3/HdkIufR9xt
   / Quick mount #3
Did you make the bracket, that is some really nice work. I hope it all works out for you.
   / Quick mount
Thank you,
yes the brackets are homemade from 8mm steel
The Quick Mount are Vtek. The Duch dealer will send us new pistonrods
and he will try to find right size Quick Apdapters.
   / Quick mount
We drilled new holes in the Quick mount
and now it functions to tilt the tools mounted the loader
Still waiting fore new replacement Tilt Cylinders :cool:
2018 SkyJack SJ1056TH 4x4 Rough Terrain Telehandler (A52377)
2018 SkyJack...
UNUSED JCT HYD TRENCHER (A51248)
UNUSED JCT HYD...
2020 CATERPILLAR D6K2 LGP CRAWLER DOZER (A51246)
2020 CATERPILLAR...
2023 WESSEX RMX500 LOT IDENTIFIER 90 (A53084)
2023 WESSEX RMX500...
JOHN DEERE 408R (A53084)
JOHN DEERE 408R...
2014 Peterbilt 384 T/A Wet Kit Day Cab Truck Tractor (A51692)
2014 Peterbilt 384...
