Quick Hitches Quick Hitch
   / Quick Hitch #11
thatguy said:
I agree the price is especially right.. I may take a gamble and order a set and see.. Wont be the first time (or probably the last) something didnt work as expected..
brian
So order two sets. If the first one works well, send the second set to me. But if the first set doesn't work, then you'll be two for two :D.
Seriously though, the seller has a 100% feedback so there's not dissatified customer. I may take that same gamble and get a pair myself ;) .
UPDATE: I just read the seller's history which had several that bought this item. All were very satified with it. So I just bought a set myself.
   / Quick Hitch #12
Check their 100% rating. There have been complaints.
eBay Member Profile for atvxpress
Pat's Easy Change has a spring loaded latch and a stabilization system that is patented. They are American made of American steel. They come with a 100% satisfaction guarantee. JMHO.
   / Quick Hitch #13
So you went through 12 pages of positive feedback to find 1 negative comment about how it was built, when the picture clearly shows the latching mechanism that the guy is complaining about? :rolleyes: I'm not bagging on Pat's system, but I'm not a big fan of relying on springs on a piece of equipment that gets left out in the rain and sees lots of abuse. Oh, and their patented stabilization system is a u-bolt, not exactly that much more high tech than the washers that the other systems use. Sure they seem to work well, but so far I haven't seen any proof that says these cheaper units don't work just as well for about 1/4 the price.
edit: I just realized that you work for/are Pat's. I guess that explains a lot. :D
   / Quick Hitch #14
I didn't try to hide the fact that I am Pat. Sorry if I upset you. I was just pointing out some things I believe are advantages of PEC. The stabilization system consists of set screws and a u-bolt that prevent the hitch from moving on the lift arm and wearing out the ball of the lift arm. The springs are stainless steel and hold up good even if you leave your tractor in the weather. It is up to each person to decide if this important to them or not.
As always thank you for your comments.
Pat of Pat's Easy Change.
   / Quick Hitch #15
I'm not upset. I don't blame you one bit for endorsing your product, since lot's of other here endorse it also. I do believe it's a good product, I just wanted to verify that the others seem to me to be good products as well. After dropping all that money on the tractor and implements, I just wasn't ready to drop another $200 on quick hitches, especially when I wasn't sure that they would work with all of my implements. I figured since I had to get off to hook up the top link and PTO, I don't really mind putting the keeper bolt in my cheap ones. Keep up the good work, everyone seems to like your product.
MARATHON 20KW GENERATOR (A55745)
MARATHON 20KW...
Mini Margaritaville Truck (A55853)
Mini...
2012 Nissan Rogue (A50324)
2012 Nissan Rogue...
TRANSMISSION JACK & TRACTOR CYLINDER (A54757)
TRANSMISSION JACK...
Texas Post Driver Series 500 Heavy-duty Hydraulic Post Driver (A53473)
Texas Post Driver...
2016 Freightliner M2 106 Braun Ambulance (A53422)
2016 Freightliner...
