Quick Hitches Quick Hitch
   / Quick Hitch #11
Slightly off topic but how would you guys compare the Pat's system to the other quick hitches that there are out there. There are a few - Speeco, LandPride etc.... most with adjustable toplink hook things to help with non standard implements. Although I believe that anything I will get will fit the standard.
I do not specifically need something that I don't want to get off the tractor for - I don't change implements THAT often. What I would like is something that would be quick - i.e. couple of minutes to get an implement hooked on with. I have no problems with those couple of minutes being spent adjusting the toplink hook or hooking up the toplink, pto shaft - etc.
Thoughts?
   / Quick Hitch
I'm going to order a Pat's this coming payday. I have to do 90% of the implement hook-up/disconnect by myself so having this will be exellent. Thanks for the input and experiences!
Mark
   / Quick Hitch #13
mark4Jesus,
I think you're making a wise decision. Like I said, I can only speculate from the pictures of the eBay model, but it looks like you could get some problems with it. I'm certain you'll enjoy Pat's system. I know I have.
   / Quick Hitch
I ordered a Pat's hitch and received it today. I ordered it at 10:45p on Tue. night and it arrived at 4:30p on Thurs., that's fast! It was easy to install. My 12 yr. old son helped me with it and had no trouble understanding what to do. I didn't get to use today, I'll try it out Saturday. Thanks to all for the advice and comments. I'll report back after I get a chance to use it Saturday.
Mark
   / Quick Hitch
Used the Pat's Easy Change today for the first time, what a great piece of equipment! First time I looked up the plow without scraping my shin! Unhooked plow, hooked up disc in less time than it would take to hook up disc. Thanks for the advice guys!
Mark
2025 Auger Mini Skid Steer Attachment (A53421)
2025 Auger Mini...
2021 K and K System MB3L S/A Solar Towable Message Board (A55851)
2021 K and K...
2007 Ford F-450 4x4 Cab and Chassis Truck (A55852)
2007 Ford F-450...
COOPER LIGHTING CAT. NO. MHEP-22/28-175-MT (A53472)
COOPER LIGHTING...
2009 PARKER 25 T/A GOOSENECK TRAILER (A52472)
2009 PARKER 25 T/A...
2008 DRAGON 150 BBL ALUMINUM VACUUM TRAILER (A53843)
2008 DRAGON 150...
