Quick Hitches Quick Hitch?
   / Quick Hitch? #11
On mine, that would usually tip the implement back too far, even with the top link adjusted short.
But on one implement, that idea did work using my adapter in post #7. It had the lower than standard pin height, about 13 inches. The adapter went upwards at about a 45 degree angle, then I put a pin and bushing in a close hole and through the hitch hook.
Bruce
   / Quick Hitch? #12
You should not use the hook on a movable part. It could come loose and damage something. If you use a link pin it.
   / Quick Hitch? #13
Agreed, but in my case it could not come out of the hook without lifting the implement, which was held down by the lower hook latches.
Bruce
2011 Kubota KX080-3 Midi Excavator (A56857)
2011 Kubota...
3PT HAY FORK (A52708)
2019 ALLMAND BROS, INC. ALLMAND BROS, INC. (A55745)
2019 ALLMAND BROS...
30KW GENERATOR (A58214)
30KW GENERATOR...
2019 KENWORTH T680 TANDEM AXLE SLEEPER (A58018)
2019 KENWORTH T680...
2005 CHANDLER  500 BBL FRAC TANK (A58214)
2005 CHANDLER 500...
