3-Point Hitch Quick hitch
   / Quick hitch #1
rlluellyn
ketchikan
Kubota BX-25
Does anyone have any ideas on a good quick hitch for a Kubota bx 25. Thanks
   / Quick hitch #4
Get a John Deere imatch. I don't think it can be beat for the price and quality.
With Pats easy change you will need a longer toplink and the thing to hold the lift arms in place.
With a quick hitch you will need quick hitch compatible equipment.
   / Quick hitch #6
Here is a video I made showing some of the differences between a harbor freight QH and a JD Imatch
There are a few modifications that need to be made to a harbor freight quick hitch to get it going. Click the link in my sig.
   / Quick hitch #7
I use a HF, cheap; but does not come with all the bushings and pieces the others do. Put it all together for half the price of a Land Pride the dealer wanted to peddle.
Ron
X2. The higher-quality gear is sure nice but the HF has been acceptable for my needs (LP rotary cutter aka shredder, LP rake, Armstrong box blade, brand X grader blade). I haven't needed to modify anything.
   / Quick hitch #8
I bought the Pat's when I bought my tractor. I did end up buying a longer top link due to the additional length the Pat's adds. I'm actually very glad I did though. The new top link was like $30 and is a much better and way more easy to adjust top link than what came on the tractor originally. I have all my attachments set at the same widths for the lift arms and I find it so simple to change implements by myself. 94BULLITT mentions something to hold the lift arms in place. I'm not sure what that is, because I don't have that and apparently don't need that. Maybe some do and some don't.
   / Quick hitch #9
Also with a PEC you might need to "lengthen" your PTO shaft. A $20 or less piece at Agri-Supply.
   / Quick hitch #10
On a BX you will need something to hold the lift arms out. They have "check chains" not telescopic stabilzers. Look at Pats website, they have a bar for this.
1982 LeeBoy Motor Grader (A52128)
1982 LeeBoy Motor...
Gravelly Pro-Turn 148 48in Zero Turn Mower (A48082)
Gravelly Pro-Turn...
UNUSED FUTURE SKID STEER MOUNTING PLATE (A51244)
UNUSED FUTURE SKID...
2014 MAC CXU613 Semi (A50514)
2014 MAC CXU613...
PREVIEW DATES AND TIMES (A51573)
PREVIEW DATES AND...
John Deere 506 3 pt Mower (A50515)
John Deere 506 3...
