Quick hitch
   / Quick hitch #1
unreconstructed
Platinum Member
West Texas
JD 5325 JD 5203 JD 2320 LT 133
I bought a quick hitch for my 5325. I thought it would fit the MX 6 but found the pins on the MX6 are a couple of inches short even with JD's expensive little adapter kit.
Anyone made a modification to make this rig up work?
Thanks.
   / Quick hitch #2
Did you buy the category I (Imatch) or a category II quick hitch??
   / Quick hitch #3
Thanks.
how hard was it to make your MX6 quick hitch compatible?
   / Quick hitch #4
I have a 4120 and a MX6 with IMatch, works great out of the box.
I beleive a JD kit is available to make them work, it is a no cost option when ordered (I think). My dealer mention something about it when I ordered.
Glenn
   / Quick hitch #5
The MX6 comes Imatch (cat I) compatible. I am wondering if on the tractor he is using he might have a cat II hitch.
You can convert the MX6 to CAT II which the OP might be referring to in his post but I do not know if the CAT II conversion makes it quick hitch compatible??
   / Quick hitch
Been out at the place the last few days. Thanks for the replys.
The quick hitch for the 5325 must be a Cat II. I have an I match on the 2320 and is not the same set up. The pins on the MX 6 are roughly two inches short on each side even with the bushing adapter set up. I had not visited with the dealer to see if there are longer pins that can be installed. Will give him a call and see.
   / Quick hitch #7
The MX6 can be converted to CAT II.
Installing Category 2 Hitch Pin Conversion Kit (MX5 and MX6)
1. Remove existing lock nut and hitch pin from masts.
IMPORTANT: During assembly, make sure bracket (B) is positioned correctly so it sits flatly at lower attaching point.
2. Assemble category 2 hitch pin (A) through hole in top of bracket (B). Fasten to mast using hardware (C-E). Leave loose.
3. Attach bottom of bracket to mast support using M16 x 45 flange-head cap screw (F) and lock nut (G).
4. Tighten all hardware to specifications. Specification
Hitch Pin Nut (D) -Torque 590 Nキm (435 lb-ft)
A-Hitch Pin
B-Bracket
C-Washer
D-Flange Nut
E-Bushing
F-Flange-Head Cap Screw, M16 x 45
G-Lock Nut, M16
   / Quick hitch
That's for that info. Called the parts man--he had to go to the salesman to get the kit number. Will run just a little over 100 bucks. Seems like its sort of a mystery to all the salesmen how to get frontier and JD equipment quick hitch and I match compatible at the time of the sale. Its a little irritating, but I suppose a lot of the rig ups are not done that often.
2018 Rock Solid 8x28 Cargo Trailer - Generator & A/C, Work-Ready (A52128)
2018 Rock Solid...
VENTRAC 4500Z ARTICULATING TRACTOR (A51242)
VENTRAC 4500Z...
3400 (A47384)
3400 (A47384)
Champion C80 B (A50322)
Champion C80 B...
2016 Big Tex 24ft. T/A Flatbed Trailer (A50322)
2016 Big Tex 24ft...
2019 GENIE GTH-5519 TELESCOPIC FORKLIFT (A51242)
2019 GENIE...
