3-Point Hitch Quick Hitch won't fit on my XR4140
   / Quick Hitch won't fit on my XR4140 #22
I have exactly the same issue with my quick hitch on my mahindra tractor
   / Quick Hitch won't fit on my XR4140 #23
   / Quick Hitch won't fit on my XR4140 #24
I ran into the same issue. I ended up going the Pat's route over a quick hitch. You can see my thread here that I started on this issue:
Quick Hitch issues
   / Quick Hitch won't fit on my XR4140 #25
Old thread but I think the take away is category 2 lower link balls will not fit into a category 1 quick hitch.
Category 2 lower link balls are approximately 1 3/4" wide and category 1 lower link balls are approximately 1 3/8" wide.
If you have a category 1 quick hitch and an XR/MT LS tractor with the extendable lower links that are category 2 they are removable and can be replaced with category 1 extendable link ends. This mod allows the use of your category 1 quick hitch and is cheaper than the Pat's system and even moreso if you have a quick hitch already.
Note if your lower links are category 2 so is the implement side of the top link. That won't fit in the category 1 quick hitch either.
2025 J & C Suppliers Enclosed Trailer (A56859)
2025 J & C...
2023 Kubota L3560 Compact Utility Tractor with LA805 Front Loader (A55315)
2023 Kubota L3560...
UNUSED FUTURE 12" HYD AUGER (A52706)
UNUSED FUTURE 12"...
2016 Ford Escape SUV (A56859)
2016 Ford Escape...
MASSAGE CHAIR (A58214)
MARATHON 76KW GENERATOR (A55745)
MARATHON 76KW...
