Quick Hitch Spec.'s...Lift force?
/ Quick Hitch Spec.'s...Lift force? #1
trlong
Platinum Member
Vermont, USA
J.D./4115
Quick Hitch Spec.\'s...Lift force?
I have a JD "Quick Hitch" front mounted hydraulic lift/hitch for my 4115, for use on my 47" Snowblower (also works with front blade and sweeper attachment, as I understand it).
Has any one ever seen spec.'s on the lift force for this? I know it will pick up the ~ 250 lb of the 47" blower. I'd like to know what it is actually rated at. Unless I missed something (always a good possibility) there is nothing in the install manual that spec.'s it's lift capacity.
Tom
/ Quick Hitch Spec.'s...Lift force? #2
Re: Quick Hitch Spec.\'s...Lift force?
Tom...
Would love to see some pics, got any ??
Eric
<font color="blue"></font><font color="blue" class="small">( Tom...
Eric )</font> </font>
Eric,
Pretty raining this afternoon but I managed to get a few pic.'s.
Here's the hitch (lift frame) that hangs off the 4115, sits in lower hooks and long pin holds the top in.
Here's the front hydraulic lift that hangs off that frame.
This is the receiver on the CUT that the hitch mounts to, then the lift hangs off.
Here's the lift, ready to mount on the hitch (hitch already on CUT...took about 30 sec.'s to install)
A side view of the lift, mounted.
Lift in lowered position.
Lift raised.
Now I have to figure out it's actual lift force and if I can design a "carry-all" that will easily attach to the 3ph and quicly changed over to be attached and lifted by the front lift/hitch.
Eric,
Just FYI, it took 10 times as long to take the pic.'s and post them than it did to throw on the hitch mount, hydraulic lift, and attach the lines. Pretty sweet setup.
Tom
/ Quick Hitch Spec.'s...Lift force? #11
Tom...
Nice setup !!
I'm surprised that I haven't seen this before.
What kind of $$ ??
Eric
Eric,
Really couldn't tell you the $$'s. It was part of the 47" snowblower purchase. I have not seen the hitch/lift priced separately. If you are interested, I guess you have to ask a J.D. Dealer. They should be able to get it separate. The only part number I have is the number on the very brief "Product Services Information ( Installation Instructions)", the instructions themselves are p/n M147702 B2. There is a parts list but, it simply gives qty and description...no p/n's /forums/images/graemlins/frown.gif.
My hitch may be specific to the 4100, 4110, and 4155 CUT's, not sure. You might require a different one.
Tom
/ Quick Hitch Spec.'s...Lift force? #13
Tom...
Once again, I like it !!
Enjoy, Eric
JOHN DEERE 7330 PREMIUM TRACTOR (A64280)
JOHN DEERE 7330...
2015Ford Escape SUV (A61574)
2015Ford Escape...
NEW 2025 Mini Skid Steer Stand On Loader (A62679)
NEW 2025 Mini Skid...
Landhonor RGB-11-72, 72" Rock Grapple  (A62679)
Landhonor...
2018 22ft. Tycorp Vector Belt VB-16H (A60352)
2018 22ft. Tycorp...
203201 (A60429)
203201 (A60429)
