Quick Hitch Repair
/ Quick Hitch Repair #1
kabong57
Wenona,IL
8260 NH, 1532MF, YM2000 Yanmar, 930 Case,
I use a lot of different pieces of equipment connected to my Quick Hitch. I also need to remove it any time I mount the Backhoe. The holes for the 3pt. linkage pins have really worn bad and have gotten very sloppy. I purchased a pair of 3/4" and 2 pair of 7/8" steel shaft collars for the repair. From my previous job at a machine shop I have gotten in the habit of saving a lot of old bearings as they have been replaced. Some times the complete bearing or just the inner or outer races. These old pieces are very useful with my shop press or as spacers when fabricating things. They also make great guides when using a hole saw during repairs. Using a good straight hitch pin and the shaft collar to locate the bearing before clamping the bearing in place. Then using the bearing as a guide to enlarge the worn hole. I then welded the shaft collar in place. This gives a larger surface for the pins and tightens every thing up nicely. An added bonus was how the bushings took out the gap on the top link adapter. IMG_3430.JPGIMG_3432.JPGIMG_3431.JPGIMG_3433.JPGIMG_3436.JPGIMG_3439.JPGIMG_3440.JPGIMG_3445.JPGIMG_3442.JPG
/ Quick Hitch Repair #2
:thumbsup:
/ Quick Hitch Repair #3
Excellent fix!
2015 FREIGHTLINER CASCADIA 6x4 T/A DAY CAB TRUCK TRACTOR (A59906)
2015 FREIGHTLINER...
2022 EZ-GO ELITE...
2018 Navigator RT-6500 6,500lb Piggyback Forklift (A61567)
2018 Navigator...
2005 Mack Vision CNX613 (refurbished and retrofitted as novelty pick-up)  (A62613)
2005 Mack Vision...
2017 Ford F-150 Ext. Cab Pickup Truck (A61572)
2017 Ford F-150...
Packer 750 Horizontal Grinder (A65579)
Packer 750...
