quick hitch half shell bushings vs full bushings on attachment
   / quick hitch half shell bushings vs full bushings on attachment #1
lamanated
Nova Scotia and Zephyrhills Fl
BX2360 JD 425 jd 455
Just throwing out a question,,I have a deere Imatch hitch, using cat 1 attachments, rather than install bushings, any prob with making a half shell set and cementing them to the hitch?
   / quick hitch half shell bushings vs full bushings on attachment #2
Unless you braze weld them I don't think cement will work. The forces are too great. Also, the bushings limit vertical movement in the hitch. The JD engineers are smart and thought this out. Stick to the design.
I use the cheap TSC bushings, 1 to 2 and cat 2 to 3, and a hitch pin. The bushing steel is so soft it wallers out/ smashes and gets bigger. It is a slow process and if you have a smaller tractor may not happen.
Someday I'll buy a piece of shaft grade steel and turn some on my engine lathe.
The Imatch is fantastic, especially the older non adjustable model. It is the best addition for my tractor. The only time I don't use it is if I borrow an attachment.
You are wise to get it.
   / quick hitch half shell bushings vs full bushings on attachment #3
Go with JRP's suggestion to use the cheaper bushings from Tractor Supply. Agri-Supply has them too, BTW.
sounds good, I got them and actually it was the old style I bought,,
   / quick hitch half shell bushings vs full bushings on attachment #5
I can appreciate your original intent though.
First time I bought a bushing kit (from Deere), it cost $80!!!
After that, I went with Agri-Supply's kit....which were the two lower link bushings and roll pins. Same bushings as the Deere kit...only difference was the Deere kit had a bushing for the upper link too. Those are available at many hardware stores for a couple bucks.
2014 Ford F-550 4x4 Ext. Cab Auto Crane 6406H 6,000LB Crane Service Truck (A50323)
2014 Ford F-550...
2017 Ford Explorer AWD SUV (A51694)
2017 Ford Explorer...
2008 Ford F-250 4x4 Knapheide Service Truck with Liftgate (A51692)
2008 Ford F-250...
2021 JCB 1CXT Skidloader/Backhoe (RIDE AND DRIVE) (LIKE NEW) (A50774)
2021 JCB 1CXT...
2020 KOMATSU PC360LC-11 EXCAVATOR (A51242)
2020 KOMATSU...
2021 GMC SIERRA CREW CAB TRUCK (A51406)
2021 GMC SIERRA...
