Quick Hitches Quick Hitch from TSC
/ Quick Hitch from TSC
Loges1 -
</font><font color="blue" class="small">( I'm in the process of building my own quick hitch. The width and top to bottom hook spacings are cat 1 standards)</font>
What is that "standard"? I measured all my 3pt implements and the spacing various all over the place.
</font><font color="blue" class="small">( but the hooks are sized for cat 2 pins. 1 1/8" bottom and 1" top. That was more by accident than design)</font>
Since you're building your own, wouldn't it be better to make the hooks fit 7/8" pins? Then you wouldn't need the adapters/bushings.
/ Quick Hitch from TSC #22
There appears to be a great deal more pin wear when using a quick hitch. (In actuality, it's a combination of most hitch designs wearing the pins faster and the fact that most folks using a quick hitch use their implements more.) It's both quicker and cheaper to change the bushings than to change the lift pin, especially when some of the pins are welded in. In addition, the better flanged quick hitch bushings are hardened (you can tell the good ones from the cheap ones by the finish - hardened bushings are black) whereas most lift pins are cold forged.
/ Quick Hitch from TSC #23
Mosey,
Yea the plan was to make them fit 7/8" pins, but a old tip in the plasma cutter resulted in to much kerf on the cut. By the time I got the cuts squared up it wasn't to much more work with the die grinder to take them to 1 1/8"
As far as the cat1 standard I saw them posted somewere here on TBN and if memory serves correctly it is 27" inside bottom hooks and 18" center/center from top hook to bottom hook. At least that is what my mower and blade measure /forums/images/graemlins/wink.gif /forums/images/graemlins/grin.gif If I ever get any kind of implement that won't fit I'll just take the gas hatchet to it and make it work /forums/images/graemlins/grin.gif
/ Quick Hitch from TSC #24
The implement standard is 15" vertical from center of lift pin to center of toplink pin. Depending on which variation you are looking at the flange to flange distance on the lift pins is either 26 or 26.5, so if your inside of hook to inside of hook distance is 27" you'll be able to connect reliably.
/ Quick Hitch from TSC #25
Thanks for setting the record straight Jim. I don't really have a memory problem, just a recall problem /forums/images/graemlins/confused.gif
2016 CATERPILLAR 308E2 CR EXCAVATOR (A64279)
2016 CATERPILLAR...
John Deere R15 Rotary Cutter (A64047)
John Deere R15...
(50) UNUSED 3'x8' CORRUGATED METAL SHEETS (A64281)
(50) UNUSED 3'x8'...
Towable Generator (A60352)
Towable Generator...
iDrive TDS-2010H...
2017 Ford Escape SUV (A61574)
2017 Ford Escape...
