3-Point Hitch Quick Hitch for JD equipment
   / Quick Hitch for JD equipment #1
jimjo2
Northern Indiana
John Deere 2520, 5303, 5320, Z997R
I have a 2008 JD 5303 and I am considering a quick hitch for it. Doen anyone know if the off-brand units will accommodate JD implements? I have a MX7 that I want to use with it.
   / Quick Hitch for JD equipment #2
I am a iMatch user...they don't cost much more than the imitations except for the Horrible Fright ones.
   / Quick Hitch for JD equipment #3
I should be getting my new JD 4720 around Thanksgiving and am thinking about getting an iMatch Quick-Hitch which retails for $299. My dealer rep says "iMatch may NOT fit other brands besides JD & Frontier. Also, not all JD & Frontier attachments are iMatch compatible."
The 4720 will have a JD FEL, backhoe and tiller with it. In addition, I have already have a rear snow blower and a 6' scraper blade I plan to use with the 4720. I may get a 7' rear scarper blade and/or a box blade next spring which may or may not be JD / Frontier products.
Given my current and planned attachments would an iMatch Quick-Hitch be beneficial?
   / Quick Hitch for JD equipment #4
I've been using Imatch for years....I know Landpride fits them...but anything else I 've just made it fit the tractor...a little fabrication is all is needed...no big deal....wouldn't be without the Imatch...I've converted King Kutter stuff to Imatch and other items...I can't see why a person would not have one....
   / Quick Hitch for JD equipment #5
I have Imatch on my new 4720 w/cab. Works great!
JPC
   / Quick Hitch for JD equipment #6
jcalla, what do you have for attachments including brand?
   / Quick Hitch for JD equipment #7
JD Ballast box, Kingcutter 6' tiller, old 7' bushog, liliston 8' finish rotary mower, 8' Ford blade, 7' york rake. What I have had to do is shim the inside of the ballast box to take up the slack and on some of the others I have had to install bushings on the implement using liquid naid to hold bushings in place. Befor I bought the JD Imatch I looked into others which were a lot cheaper but were not built as rugged as JD Imatch. The Landpride is more expensive and has a feature to adjust the toplink. It also has a auto leveling link hook up on the toplink. JD Imatch gave me the best bang for the buck!
JPC
   / Quick Hitch for JD equipment #8
So long as the hitch maker follows the basic cat measurements are followed and the att unit has enough rooms for the hooks. Keep in mind that the "I-Match" is the catI quick hitch you will want a catII hitch for your unit.
catII inside lower width 32 3/4, mast height 15"
   / Quick Hitch for JD equipment #9
IMatch has a welded in place top hook where some other brands have an adjustable hook, I can't see the benefit in having an adjustable link on something that should be uniform in design. If you take the time to make all the implements fit properly the IMatch is quick and easy to use. This is particularly evident with the increased weight of Cat II implements.
2017 Ford Explorer AWD SUV (A56859)
2017 Ford Explorer...
2013 Ford F-250 (A55973)
2013 Ford F-250...
2019 MACK PINNACLE (A55745)
2019 MACK PINNACLE...
2008 Ford Ranger Pickup Truck (A54814)
2008 Ford Ranger...
2013 Ford Taurus SEL Sedan (A56859)
2013 Ford Taurus...
2005 Kaufman Trailers Car Hauler Trailer (A55787)
2005 Kaufman...
