Quick Hitch disappointment
   / Quick Hitch disappointment #21
The World of Quick Hitches is a learning World.
The first lesson is, all implements need to be built to QH specs or modified to QH specs. Once this is accomplished the QH is your lifelong friend and you'll never remove it from the tractor. Without doing that it's basically non effective and a waste of your money.
The second lesson is, regardless of brand, i.e., JD I-Match, LP, Speeco, Harbor Freight, whatever, if the attachment is not QH compatable, it ain't gonna fit. Again, becomes a waste of money.
The third lesson is, generally speaking the extra money paid for a QH buys you strength and durability and not much else. I use the snot outta my QH, both CAT I and CAT II. I bought a Northern Tool CAT I and bent it. My CAT II is an antique and I don't even know the brand. It's built bull strong. I often throw a chain around the main beam and using the 3pt to lift, pull all my M9540 can pull with no worries about bending it.
If all you are after is light duty use of your QH, buy cheap. If you are going to fully use it to it's design capability, buy quality and pay more money.
If you are only going to change 3pt attachments a few times a year, save your money and learn to use the tractor's 3pt arms.
If you are going to change 3pt attachments several times a week and sometimes several times a day, buy a quality QH, modify your attachments to fit and live the good life.
   / Quick Hitch disappointment #22
Excellent post, thank you. Sort of hits the nail on the head. ;)
   / Quick Hitch disappointment #23
Then throw in Tnt and you start seeing rainbows and butterflys and hearing Angels sing!!!! :cloud9:
I pay little attention to terrain when dropping an attachment because picking it back up is very easy. Only time I get off the tractor is to latch the QH if necessary and/or hook/unhook the PTO.
   / Quick Hitch disappointment #25
I agree working in the field I have to drop an implement where it isn't in my way. With the IMatch and tnt it doesn't have to be a perfect spot.
   / Quick Hitch disappointment #26
sometimes spending more money accomplishes nothing. We all know that, just hope it doesn't play out.
Well....I read the articles here about quick hitches. I've played with the levers in Tractors Supply, looked at the Speeco,
but the more I read about incompatibility the more I felt buying the oem quick hitch would save a lot of aggravation.
Hey, if I paid $400 for a quick hitch that others make at $139 and $279 price points, well, this should be one seriously good
quick hitch and should handle anything.
Wrong.
The Land Pride company, as you know, has the oem supplier deal with Kubota, and touts their compatibility with Kubota.
So why then Land Pride does your very expensive quick hitch not work on the oem ballast box Kubota supplies?
The attachment I most take on and off, is difficult to horse around to line up, and was a primary reason to buy the quick hitch, and your
hitch doesn't work with it, even with adapters?
So, lesson of the day. Land Pride and Kubota's engineering departments really took a snooze on this one. They need to wake up.
The dealer is now figuring out how to get different pins for the ballast box, likely wider and will have to do some welding to make this work.
I told him to get it done or keep the quick hitch and he understood and agreed completely. And scratched his head like I did.
All I can think of is that the Kubota ballast box is seriously off spec for a Type 1 three point hitch. Well, it goes on with the stock arms, right?
yeah, for a daily dose of grease on your hands and using a long bar to move the thing in line. I have very bad arthritis and I need to make this easier on my body, and
when they emailed me the invoice for the job, and I read the note attached, it sure was disappointing.
REMOVE BALLAST BOX AND MOUNT QUICK HITCH
ATTEMPT TO REMOUNT BALLAST BOX--WILL NOT WORK WITH HITCH
But, that's what welders are for and it will get fixed. And hopefully on not too much of my dime.
so when you go shopping for a quick hitch, the fancy ones, from my experience, do NOT afford greater compatibility. Your results may vary...
Not sure what your ballast box looks like but you could probably pick up a cat 1 draw bar that fits the QH and weld or bolt it to the front of your BB. That's what I have to do for my rake which has cat 0 spacing. My back blade is cat 1 and fits the QH on the bottom hooks but I have to make an adapters for both top link connections because there is a steel brace in the way so the QH hook can't connect as it is. I'm not going to sell my existing 3 pt. equipment for a loss just to buy new compatible QH implements. All the old equipment will fit when I get done. Any new 3 pt. stuff I buy will be QH compatible so It doesn't need modification.
I had to chuckle because after watching that video of the Alexander hitch, I realized I had been thinking the same universe myself; i.e. why can't the rear work the same as the front quick attach on my Kubota? I have no problems with the bucket or bucket/grapple at all. and here is the same slide up the narrowing retainer concept in a rear application. I think those adapter plates need to go on a diet, at least a cost diet to make sense. Unless someone is playing swiss army knife with their tractor and is swapping implements like frankly most of us don't, at least not frequently, it's hard to find value for the occasional user like me, even if I would like the ease.
But :thumbsup: on the design, it sure makes sense to me.
   / Quick Hitch disappointment #28
   / Quick Hitch disappointment #29
The problem with this approach is that you need to modify every single attachment, at $400 per.
Cheaper, easier and better customization to simply change the attachment, ie weld new pins, tabs, whatever.
The way you guys were talking, $$$$ was no object, so all you have to do is buy one of the receiver implement plates for each implement at $372 ea, no modification required and you are all set. I believe that they are designed to fit about any 3pt implement.
So you don't really have to modify anything, just put the receiver plate onto each implement and you are good to go in just about any situation. And all it takes is a little bit of $$$$. :rolleyes:
   / Quick Hitch disappointment #30
Say what you will. I love my JD iMatch hitch on my Kubota. Handy as a pocket in a shirt.
Yes you will have to modify some implements if they aren't quick hitch compatible. That's how it goes.
It is odd the Kubota weight box is not quick hitch compatiable.
2017 FREIGHTLINER M2 S/A SWEEPER TRUCK (A51406)
2017 FREIGHTLINER...
UNUSED CFG INDUSTRIAL STSD10 QUICK ATTACH SEEDER (A51244)
UNUSED CFG...
2022 30ft 20k Blazer Deck-Over Trailer (A52128)
2022 30ft 20k...
UNUSED AGT DM20 EXCAVATOR (A51243)
UNUSED AGT DM20...
UNUSED AGT MH12RX EXCAVATOR (A51243)
UNUSED AGT MH12RX...
(4) HD 16' Pipe Gates (A50515)
(4) HD 16' Pipe...
