quick hitch cat 1 for cat 2 tractor
   / quick hitch cat 1 for cat 2 tractor #11
I just checked a Cat 1 Land Pride QH15 quick hitch. The bottom openings for the 3 pt lift arms are 1-7/8 inch wide.
The lift arms may be designed to have replaceable balls, if so get cat 1 balls for lift arms.
the t4020 has replaceable balls but the workmaster 55 doesn't have them.
Thank you, I will run by the kubota place down the road and take a look, I think that will work. I had a harbor freight one several years ago that the bolts for the top hook got in the way. the Imatch is a welded hook so no issues there. do the land pride bolts rub on anything or is the hook stuck further to the rear?
I want to stay with the quick hitch vs pats as I've already modified most everything to fit that didn't come that way from the factory.
   / quick hitch cat 1 for cat 2 tractor #14
I had the same problem with the upper bolts and clearance issues on a HF hitch. The top hook on the Land Pride sticks out further and so far no issues. I have 2 implements that need some work to be quick hitch compatable.
Thanks for that, I just wanted to make sure before I spent the money on it that it will work.
   / quick hitch cat 1 for cat 2 tractor #16
Is there a quick hitch that will fit cat 1 implements that will fit on a cat 2 tractor. My Imatch is only 1-3/8 wide where the lift arms fit and my new holland tractors have cat 2 lift arms that have 1-3/4 wide lift bushings. I don't want a cat 2 width quick hitch as the cat 1 quick hitch will fit all of the cat 1-2 implements as well as the cat 1 only stuff. I have looked around but haven't found anything.
LeeAgra Farmhand quick hitch-cat 2 on tractor side, cat 1 on hitch side. Got on wait list late last year, got mine in easels spring. Works great-built like a brick ****house.
Use mine on an LS XR4155HC
   / quick hitch cat 1 for cat 2 tractor #17
What GSVette said. I have one and LOVE it! And it's Cat 1 & 2 on the tractor side! And it has 2 5/16-3/8" grab hooks welded on each side! And it has 3-2" Reese hitch sockets welded on it, under the top link and below the lower links!
   / quick hitch cat 1 for cat 2 tractor #18
Forgot to mention those additional features-just finished using the hitch feature to move a trailer into the shop for rewriting.
Farmhand was well worth the wait.
Thanks, I like the looks of the farm hand however when I go to their website it looks like they might have discontinued it, lots of missing links and can't see a price anywhere.
   / quick hitch cat 1 for cat 2 tractor #20
Give them a call and see if they have indeed discontinued it or if they'll build you one...and post back here with their answer please!
2017 Makita HM1307CB 35lb Demolition Hammer (A49461)
2017 Makita...
2022 Chevrolet Equinox Traverse SUV (A48082)
2022 Chevrolet...
2014 CATERPILLAR 277D SKID STEER LOADER (A51222)
2014 CATERPILLAR...
Misc Machine Tools (A50860)
Misc Machine Tools...
Seppi Mini BMS 85 Mulcher excavator attachment (A51039)
Seppi Mini BMS 85...
2015 Ford Escape AWD SUV (A50324)
2015 Ford Escape...
