Quick Hitch and Blade for 425
   / Quick Hitch and Blade for 425 #1
gleward
I have an opportunity to purchase a quick hitch and blade from x495 or x700 series tractor. Does anyone know if it will fit the 425 series?
   / Quick Hitch and Blade for 425 #2
Best way to find out is to go to JD build it yourself and look at the blade. It will list the quick hitches for the various tractors. I think in this case the blade is interchangable but the quick hitch is different.
Todd
   / Quick Hitch and Blade for 425 #3
Yes it will fit - the only difference is the hoses are longer. I put a hitch and blade on my X485 from a 445 and the only thing needed was a hose extension kit.
   / Quick Hitch and Blade for 425 #4
Thanks for the reply. Looking at the posts, it looks like you can take a 425 quick hitch and mount it on the X series but can not go backwards? Is there a modification I could do to allow the newer quick hitch fit the 425?
   / Quick Hitch and Blade for 425 #6
I think yes, if you have access to a cutting torch and/or a plasma cutter. Maybe some welding.
Might consider selling the hitch and picking up one that fits the 425. The blades will fit both quick hitches.
10855 Pumping Unit- ENGINE ONLY (A52128)
10855 Pumping...
2006 MACK CV (GRANITE) BOB TAIL KILL TRUCK (A50854)
2006 MACK CV...
Gator XUV560S4 (A50324)
Gator XUV560S4...
2018 Dodge Ram 3500 4x4 Utility Flatbed Truck - HEMI Gas, Gooseneck Hitch, Southern Truck (A52128)
2018 Dodge Ram...
2021 Western Star 4700SF Tri Axle Dump (A47384)
2021 Western Star...
2020 Kinze 3505 High Speed 6/11 Planter (A52128)
2020 Kinze 3505...
