Quick Hitch and Blade for 425
   / Quick Hitch and Blade for 425 #1
gleward
I have an opportunity to purchase a quick hitch and blade from x495 or x700 series tractor. Does anyone know if it will fit the 425 series?
   / Quick Hitch and Blade for 425 #2
Best way to find out is to go to JD build it yourself and look at the blade. It will list the quick hitches for the various tractors. I think in this case the blade is interchangable but the quick hitch is different.
Todd
   / Quick Hitch and Blade for 425 #3
Yes it will fit - the only difference is the hoses are longer. I put a hitch and blade on my X485 from a 445 and the only thing needed was a hose extension kit.
   / Quick Hitch and Blade for 425 #4
Thanks for the reply. Looking at the posts, it looks like you can take a 425 quick hitch and mount it on the X series but can not go backwards? Is there a modification I could do to allow the newer quick hitch fit the 425?
   / Quick Hitch and Blade for 425 #6
I think yes, if you have access to a cutting torch and/or a plasma cutter. Maybe some welding.
Might consider selling the hitch and picking up one that fits the 425. The blades will fit both quick hitches.
3 pt Rolling Basket & Harrow (A50514)
3 pt Rolling...
2018 Ford Explorer AWD SUV (A50324)
2018 Ford Explorer...
2003 Big Tex 10PI 16ft. T/A Pipe Top Utility Trailer (A49461)
2003 Big Tex 10PI...
REYNOLDS 100 - 8 YARD PULL TYPE SCRAPER PAN WITH DRAWBAR (A51039)
REYNOLDS 100 - 8...
2013 GALYEAN 130BBL VAC TRAILER (A50854)
2013 GALYEAN...
2019 CATERPILLAR 299D2 XHP SKIDSTEER (A51242)
2019 CATERPILLAR...
