Quick hitch & an RFM with a "floating top link"
   / Quick hitch & an RFM with a "floating top link" #1
Mechanos
Roosterville, MO
JD 955/70A/7 TLB
I've been considering the purchase of a 3PT quick hitch. I have a rear finish mower that has a floating top link connection. Will that floating link arrangement work with a quick hitch? I don't see how it could. Is there some sort of adapter that would allow it to work with a quick hitch?
Nevermind... I think I figured out what I'd have to do. I'd have to get rid of the floating link, remove the two struts that go from the top of the A frame to the rear of the RFM and replace them chains.
   / Quick hitch & an RFM with a "floating top link" #3
I use the floating top link on my rotary brush mower just slipped into the top hook and have no problem.
Got a picture?
   / Quick hitch & an RFM with a "floating top link" #5
here is a pic of mine hand made bracket that allows me to retain the floating link on my brush cutter.
   / Quick hitch & an RFM with a "floating top link" #6
I shortened the top link to tilt the QH forward quite a bit, then used a short chain between the QH and the tower on the mower.
Seems to me this chain has all the functionality of a hinged connector.
   / Quick hitch & an RFM with a "floating top link" #7
Deere has a good approach to this issue on the MX6 brush cutters, The hinged struts are two pieces that will fold upwards when you push back on the top link connection, that means the weight of the struts are holding the top link forward in place to hook up easily. The early models were underslung and had a tendency to lean backwards at rest, could make it a pain to couple up to.
2014 UTILITY 53X102 DRY VAN TRAILER (A51222)
2014 UTILITY...
RURAL KING RK37 TRACTOR (A51243)
RURAL KING RK37...
2012 Ford F-250 Ext. Cab Omaha Service Truck (A50323)
2012 Ford F-250...
2017 Ford Explorer AWD SUV (A50324)
2017 Ford Explorer...
2019 Harley Davidson 114 Police (A50324)
2019 Harley...
2019 VOLVO VNL760 TANDEM AXLE SLEEPER (A51219)
2019 VOLVO VNL760...
