Quick garden structure (pergola)
/ Quick garden structure (pergola) #1
GLyford
Veteran Member
MA
In another thread, I said I would post how this project went together once it was done, so here it is.
An aluminum deck vendor was mentioned in another thread, Aluminum Decking, Railing, Fencing, Pergolas and Deck Framing by Nexan Building Products and I was looking to see if they had something suitable to use to make a pergola. I was hoping to come up with something that would not rot or need regular repainting.
They not only had something suitable, they had complete kits in a number of sizes and a couple of styles so I ordered an 8x12 "economy" kit. Their deluxe kits have bigger fluted posts and double headers.
This is the the hardware that comes in the kit, self threading flathead screws mount the base plates to the posts. Everything else is put together with the painted self drilling sheet metal screws, except the top slats which use the longer galvanized screws. It also came with 3" wedge anchors, but I decided to embed carriage bolts in my concrete instead so would not have to wait for the concrete to be hard enough to take an anchor. I made a jig out of 3/4 ply with holes copied from a base plate.
I dug four 4' deep holes (frost depth in my area) with a hand auger and dropped in 8" sonotubes and a 10' chunk of rebar, bent double, resting on a half brick at the bottom of the hole. I also made a couple of "c" shapes from 1' rebar wire tied to the bolts. Since this was to be a decorative project, I made a decorative base form and reused it for all 4 holes. This meant that I could only really pour one per day so it would be stiff enough to strip the form without damage.
The base plates went on the posts OK, but being stainless (soft) the philips heads were starting to strip by the time the bolts were all the way in. Impact might have helped? Bolting the posts to the bases was fairly painless. I got lucky, once the posts were tight to the bases they were all plumb and I didn't need to shim any.
The "headers" and "rafters" are made from 2 pieces of extrusion which snap together. I made a design change from their instructions, I mounted the headers 6" lower than what they called for so that I could attach the end two rafters to the posts as well as to the headers (their directions only attach to the headers). This meant that the stiffness in narrow direction is improved, it doesn't just come from the post base plates. I used more screws, but they were very generous with the fasteners. There were at least two extra of everything. They gave me 125 screws, and I have maybe 20 left over even after using an extra dozen. Oh, and losing 6" of height was another reason to use the base form. It made it easier to level all the bases to each other because I only had to tweak how high the form sat.
All the mitered ends get covered with decorative end caps (I think die cast from the weight). The top slats are held on with double sided 3M tape, and they include spacer blocks to make setting the spacing easier. I measured and marked 10" from the end for the overhang, and then put all the marks facing up so you would not see them from the ground. Then the ends are screwed down with long screws and there are die cast caps for the slats, too.
Overall, I like the look. The price was reasonable and included truck freight (hardware arrived separately UPS). The design appears to be robust, and since nothing is predrilled, it easily accommodated where I was off a bit in my base locations (about an inch the long way on the back posts, about half an inch the short way).
Time will tell if it holds up to sun, snow, and nor'easter winds.
Next part of the project will be a paver patio under and around it. Haven't decided which pavers I will use yet.
/ Quick garden structure (pergola) #3
Interesting. I like that it will never sag, rot, need paint or stain.
We could get severe thunderstorms this afternoon...I hope a flying branch doesn't take it out before it is a week old. If the storms do hit, I guess I will get to see a wind test.
/ Quick garden structure (pergola) #5
We are working on finalizing our deck design and then will likely get deck materials from them. It is expensive but as you say, should last.
Oh, and for anyone who buys one of these kits, get extra square drive bits. Like at least a half dozen.
Name brand bits are better, but even they can get damaged.
Swap out as soon as they start to strip (for me usually after I don't get the bit seated I will notice damaged corners/twisted tip). It can take as few as three screws. By the end, I was noticing the paint affected how deeply the bit set into the screw. If a screw isn't jamming onto the bit nicely, try a different screw or two.
I was able to make a couple of mildly damaged bits usable again by grinding back the tip a smidge on a belt sander. I kept rechecking on a screwhead until it felt like a good connection. That trick works for bad corners, but not twisted.
Maybe it is just me, but I always have this problem with square drive stuff. I have much better luck with philips, torx, and that oddball "phillips II" square drive center bit that went away after only a couple of years. Someone was telling me that American square drive has ever so slightly rounded corners, but true Canadian Robertson drive stuff has very sharp corners and behaves much better. I guess I have yet to see any real Robertson stuff if that is so.
/ Quick garden structure (pergola) #7
Same - the star drive/torx seem to work much better for me. Problem with the square for me is it is just too easy when working at an odd reach or just getting tired to get the driver a little off angle. That quickly rounds the head or the bit. The star drive are much more forgiving of sloppy drill handling....
/ Quick garden structure (pergola) #9
Nice looking project there. I didnt have much problem with my deck square drive tips. Only used 1 for entire project.
/ Quick garden structure (pergola) #10
Nice looking addition you put up. Nicely detailed narrative too. This was phase III of my deck rebuild/ beautification project. This a New England Arbors vinyl pergola (12 x 16) That I bought through Costco (cheaper than manuf.)
/ Quick garden structure (pergola) #11
That aluminum pergola looks good. GLyford, do you mind if I ask how it compares cost-wise with wood? I went to their website and they have a nice product but require an inquiry to get a price.
If you go to "shop online" they have all their prices listed without having to submit anything. This one shows the 8x12 I ordered,
Freestanding Economy Pergola
I paid extra to get the 6"oc slat spacing rather than the default 9", I probably should have gone even closer. And I think I'd get the 10' wide next time, the 8' wide really only gets you 7' wide of shade because the slats start 6" in from the ends.
This page has the economy and deluxe versions in freestanding and wall mounted. Click from there and you'll see the prices of each type.
Aluminum Pergolas
Mine was just under 2.5k, comparing to wood we'd need to nail down a few specifics.
Just straight PT posts and 2x's, carriage bolted together I think you could get it done for 1/4 of that pretty easily. I was aiming for something a little nicer than that, that would hopefully last a little longer.
If you're talking about good quality trim boards and painted, you'd be lucky to make one for half that I think, bought as a kit or completed unit it could be more than I paid.
If I had seen a vinyl kit anything like that one I probably would have went with that. We don't have a costco nearby, so didn't think to look there. The box store kits all had main beams that bolt together in sections. They looked hokey, cost a fair bit and I'm not convinced they'd last very long. They'd probably be OK, really, but I guess I just didn't like them.
I was pricing fiberglass porch posts and such leading up to this, trying to think up ways sandwich vinyl trim boards around metal pieces. Doing that I certainly could have spent this much easy to come up with something that doesn't look as nice, been a lot more work, and kept me busy all summer.
I was debating getting some logs (white oak or cedar, maybe) from a local tree service and making a log structure. Or a combination of welded metal trusses (I was thinking of getting some shapes plasma cut to make up the web of the trusses) and either log legs or even something like concrete with a structural metal core, poured on its side then bolted upright once cured. But all of those options would have required a lot more lead time, and I was really hoping for something that get me closer to done sooner, so this really fit the bill.
/ Quick garden structure (pergola) #13
Thanks. Somehow I missed that. They look good and for sure they'll last forever.
I quite understand, I hate shopping for things without seeing the prices first.
Used Landpride GR1525 Stump Grinder
Used Landpride...
2020 DRAGON ESP...
Root Rake Loader Attachment (A59228)
Root Rake Loader...
2015 Ford Escape SVU (A61569)
2015 Ford Escape...
TANK MANIFOLD (A60736)
2015 FORD F-250 SUPER DUTY (A60736)
2015 FORD F-250...
