Quick Connects for max flow?
   / Quick Connects for max flow? #11
I was shocked when I saw how small the lines from the SCV to the couplers is on my JD. Once I realized just how small they were I quit worrying about the need for large lines from the quick couplers on.
   / Quick Connects for max flow? #12
Were the lines steel or hoses. Steel will look smaller, but carry the same flow as what looks like a larger hose. If they both are say 1/2, then they should carry the same flow.
have to slap a calipers on, but its a rubber hose, certainly no more than 1/2" I'd bet.
   / Quick Connects for max flow? #15
J_J, Put the slide caliper on the metal part of the lines this weekend and they are 1/2" OD so my guess is 3/8" ID allowing for 1/16" wall thickness.
   / Quick Connects for max flow? #16
If the ID of your line is 3/8, then use 1/2 in QD's to prevent any pressure loss or flow restrictions.
Mitsubishi FG35 Forklift - 8,000lb Lift Capacity, LP Gas (A51039)
Mitsubishi FG35...
2017 Ford F-450 Crew Cab Knapheide Service Truck (A49461)
2017 Ford F-450...
FUEL TANK (A50854)
FUEL TANK (A50854)
PAIR OF 29 FT PIPE RACKS (A50854)
PAIR OF 29 FT PIPE...
John Deere 1100 3 pt Field Cultivator (A50514)
John Deere 1100 3...
1996 Monon 45X96 Dry Van Trailer (A51039)
1996 Monon 45X96...
