Quick connect.
/ Quick connect. #1
idaho181
Nezperce, Idaho
Kubota L4600 HST, 1963 D-4 Dozer
I have a new L4600 HST. I was told by a neighbor that there is a quick disconnect set up for the Kubota 3 pt that makes it easier for one guy with bum knees to attach implements. I thought I saw some input here on that subject but can't find it on the web pages displayed. I was wondering as to cost and ease of use.
Appreciate it....Mike
/ Quick connect. #2
Do a search using the terms Pats Quick Hitch and Quick Hich. Then prepare to read for a while. I have a L4400HST and I use a Harbor Feight quick hitch, the draw back is your equipment needs to be quick hitch compatable or you will need to make it fit the quick hitch.
/ Quick connect.
I looked at Pats Quick Hitch. I didn't see where the Dogbone connected at on the mower he was using. Is it used ?
/ Quick connect. #4
I assume by dogbone you mean the top link. The top link is used as usual with the pats quick hitch(sometimes a longer one is needed though).
/ Quick connect. #5
I've had Pats and two different ones I've bought from ebay for under $100. Sold/traded my Pats and have kept the cheaper ebay ones. Can't use my tiller with the quick hitches since they add a few inches to the length of the arms which is just enough to make the shaft on the tiller to short.
quick hitch in Agriculture & Forestry | eBay
/ Quick connect. #6
/ Quick connect.
Thanks TripleR
Already have the Land Pride 72 in mower and the Road Grader. Haven't been able to use them as of yet. Waiting for snow to leave. I think it will be better to use the LP Quick Hitch with my Kubota if they are priced reasonable. Guess I will give the dealer a call on Monday.
Thanks
Many of the farmers in my area use the quick hitch on their John Deeres, but you would need something different like this I believe if you want to hook up your side links and top link. Other brands are available, I am just not familiar with them.
QH20 Series Quick-Hitches | Land Pride
QH15 Series Quick-Hitches | Land Pride
/ Quick connect. #8
JOHNTHOMAS
If your tiller has the Italian type dive shaft it's easy enough to lengthen it to accommodate a quick hitch. I've been using a HF QH($79) on my King Kutter ll tiller for years. In fact I need to change the tines on the tiller as the ones that follow tractor tires are worn out.
/ Quick connect. #9
JOHNTHOMAS
I have a Kubota tiller and don't know what an Italian type drive shaft is to say I do or don't have it. It just hooks in the pto at one end and the tiller gear box at the other end and slides back and forth in the midle.
New/Unused Landhonor Hand Chain Lever Hoist (A65583)
New/Unused...
Skid Steer Mount 3pt Adapter  (A62679)
Skid Steer Mount...
2017 Ford F-250 4x4 Ext. Cab Pickup Truck (A64556)
2017 Ford F-250...
2017 CATERPILLAR 745 OFF ROAD DUMP TRUCK (A65053)
2017 CATERPILLAR...
2013 DRAGON  130BBL VACUUM TRAILER (A65643)
2013 DRAGON...
2016 Dodge Charger Sedan (A64557)
2016 Dodge Charger...
