Quick Connect Problem
/ Quick Connect Problem #1
nckennedy
Camillus, NY, USA
JD 5425
Hi Guys:
I am using a skid steer mount snow plow on my JD 5425. Works great, but having difficulty connecting the Skid steer style hose connections. The connectors seem to work ok, but it takes all my strength to force the hose connection into tractor fitting. Is there an adjustment on the plow to reduce the required pressure? Is the oil pressure on a skid steer higher than on a farm tractor?
Any suggestion would be greatly appreciated.
Craig
/ Quick Connect Problem #2
You need to relieve the pressure before you disconnect the line by first turning the machine off then move the control for that remote back and forth.
125 GAL TANK (A68842)
2017 Chevrolet Silverado 2500HD 4x4 Crew Cab Reading Service Truck (A68183)
2017 Chevrolet...
AM GENERAL M1123 HMMWV 2 DOOR TRUCK BODY (INOPERABLE) (A67714)
AM GENERAL M1123...
FUEL TANK WITH PUMP (A68842)
FUEL TANK WITH...
JOHN DEERE 5045E TRACTOR (A65057)
JOHN DEERE 5045E...
1978 Fruehaue Chipper Trailer (A62613)
1978 Fruehaue...
