Quick Connect Problem
   / Quick Connect Problem #1
nckennedy
Camillus, NY, USA
JD 5425
Hi Guys:
I am using a skid steer mount snow plow on my JD 5425. Works great, but having difficulty connecting the Skid steer style hose connections. The connectors seem to work ok, but it takes all my strength to force the hose connection into tractor fitting. Is there an adjustment on the plow to reduce the required pressure? Is the oil pressure on a skid steer higher than on a farm tractor?
Any suggestion would be greatly appreciated.
Craig
   / Quick Connect Problem #2
You need to relieve the pressure before you disconnect the line by first turning the machine off then move the control for that remote back and forth.
UNUSED JCT SKID STEER QUICK ATTACH SNOW PUSHER (A51244)
UNUSED JCT SKID...
2018 TAKEUCHI TB240 EXCAVATOR (A51242)
2018 TAKEUCHI...
2025 Swict 84in Bucket Skid Steer Attachment (A50322)
2025 Swict 84in...
2019 Dodge Journey Crossroad SUV (A50324)
2019 Dodge Journey...
2021 HAMM HD+9I VO DOUBLE DRUM ROLLER (A51242)
2021 HAMM HD+9I VO...
2013 VOLVO VNM TANDEM AXLE DAY CAB (A52141)
2013 VOLVO VNM...
