Quick connect jumper cables
   / Quick connect jumper cables #1
bx24
Platinum Member
Indiana
I don't know about the rest of you, but my Kubota always has a good battery (since I use it so much) and many of my other battery powered pieces of equipment and ATV's often have dead batteries.
I got tired of taking off the center panel on my Kubota BX to get to the battery to jump it so I canobalized some jumper cables with some quick connects and I can jump and dead item very quickly. I would recommend this to anyone who "jumps" a lot
   / Quick connect jumper cables #2
That is a great idea. Where did you get your quick connects?
   / Quick connect jumper cables #4
I have simlilar but used an old dryer outlet and dryer pigtail , and some old cables.. An extrac connector for yours and you could have an extension cord for other 12 volt uses.(portable lights)
I was going to reply "Now that's some New Yankee thinking!" and then I read where you were from ... Thats great
   / Quick connect jumper cables #6
many have used welder cable plugs and sockets,
for quick connects for jumper cables,
   / Quick connect jumper cables #7
I like the looks of that quick connect. It's not like the grainger one.
bx24, mind sharing where you picked up that quick connect? It looks like it has a weather cap too?
   / Quick connect jumper cables #8
I have a set on most of my vehicles including my travel trailer so I can hook up additional house batterys for long stays with out 120v
or hook the other vehicle to the trailer to charge its battery,
tom
   / Quick connect jumper cables #9
I know what you mean .
Last december I took the panels off both BX1500s so I could jump start the other one .
As I recall, I got them online (here is one I just Google'd)
SB50 SB Series 50 Amp Anderson Powerpole Set - $4.02
I used "SB50 Anderson Power Products" connectors with the optional "T-handle" and dust cover
BTW - The black version of the plug is universal and the other colors only mate with their own color or black so what ever color you chose, you have to stick with it if you plan to use them for other applications
   / Quick connect jumper cables #11
I did this the other year. My tractor battery was always half dead, and it was a COLD winter. Every time I had to plow, the battery always died before I could get the tractor started. This was a near daily event.
So I opened up my charger, removed the charging wires. I replaced them with 25 feet of heavy duty cord, so it could reach across the garage. Then I wired in a female quick connect plug on the end. I wired in a male quick connect on the tractor battery. All it took to hook up the charger (and never worry about whether I got the terminals right) is to plug the two ends together, twist and lock.
Then in case I ever needed the charger for my car battery, I added a pigtail with heavy alligator clips on one end, with the other end a mating quick connect plug.
John
   / Quick connect jumper cables #14
The Anderson connectors are the only way to go!
Be sure to get the mid sized ones, i.e. rated for 300 amps or so.
I have used them for years now and they are bullet proof.
   / Quick connect jumper cables #19
The connector that he used is what is used on electric folk lifts and pallet jacks. They are widly available from suppliers that deal in lift equipment
   / Quick connect jumper cables #20
Anderson connectors also have rubber plug protectors to keep the dirt out when not in use. I don't know where from in your area.
Weedpharma
UNUSED FUTURE...
2005 WESTERN STAR DUMP TRUCK (A60430)
2005 WESTERN STAR...
2017 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A59904)
2017 FREIGHTLINER...
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
Toro Greenspro 1260 Towable Greens Roller (A56859)
Toro Greenspro...
2009 Jeep Grand Cherokee 4WD SUV (A59231)
2009 Jeep Grand...
