Quick Connect Fitting Help
/ Quick Connect Fitting Help
Chris just do what J.J. is suggesting here. That's if you have to.
Come to think of it that might be a good idea for me to get some more rearward tilt out of my HTL, have plenty of forward motion but could use a little more back angle.
JB.
Yeah, I went right past that suggestion. Thanks JB and JJ, that would probably be the easiest solution, but hopefully, I don't need to worry about it.
/ Quick Connect Fitting Help #22
Well I see your pic's now. Not sure what happened earlier today. I just looked at my rake and back blade and the top link mounting points don't have the long tabs that your carry-all has, but if I can get the fixed side of the cylinder to mount to the tractor top link bracket, the implement side won't be an issue. If I measured right, the cylinder itself should clear the mounting tabs on the tractor, but we'll see soon enough.
I'm starting to think of some way I can extend the fixed side swivel eye so it's further away from the cylinder - maybe a heavy duty u-bolt would move the swivel eye out some or a smaller pin would allow the swivel eye to be pulled further away from the center point of the mounting holes.
Maybe a pair of short steel plates with 3/4" holes on each end. Put them on the outside of the mounts of your tractor with a pin through it, then place another pin through the plates and the fixed end of the link. In my case, with my 10" cylinder, that would make the overall length a little too long. I still wish I had thought of it before spending the $185 ($85 more than the other cylinder costs) for the CCM one. I could have just bought a shorter cylinder from SC. Oh well. The CCM is well regarded here, so I'm sure I'll be happy with it (if not $85 poorer).
Lucky for me, I bought a cylinder 1" shorter than my current top link. I was hoping to get a little more backward angle and the blade/rake edge, but I'll sacrifice that 1" if I have to to make the hydraulic one work. It's due to arrive on Tuesday and I think I'll run right out and see how the clearance is at the tractor side right away.
Bale Spear (A66408)
Bale Spear (A66408)
Volvo VNL (A63689)
Volvo VNL (A63689)
3pt Hitch Receiver (A62679)
3pt Hitch Receiver...
(2) FIFTH WHEEL PLATES (A65643)
(2) FIFTH WHEEL...
Ellis Band Metal Saw (A62679)
Ellis Band Metal...
7' Pallet Fork Extensions  (A62679)
7' Pallet Fork...
