quick connect couplers
/ quick connect couplers #1
fountain42
Help my couplers are not so quick connect? It is a big job detaching the hydraulic connection to my snowblower chute. I tried cleaning to coupler? It's a pain in the butt removing the blower because of the fittings. Any ideas thanks
/ quick connect couplers #2
Relieve the pressure in the system before trying to disconnect.
Thanks Zebrafive but that is not the issue? there is a relief valve that I can drain. I am wandering if one of the balls? are stuck?
/ quick connect couplers #4
It's possible you have defective coupler. And since you say snowblower it could be iced up/frozen.
/ quick connect couplers #5
Does the sleeve on the QD move at all? Pushing or pulling.
Was the snow blower raised up even a little? If so, then the weight of the snow blower is causing pressure on the QD.
You will have to bleed the snow blower side of the QD. It could be messy.
J.J. the blower is on the 3pt, this is for chute rotation. I have it in my garage now to warm up I'll check into more tomorrow. maybe ice? I hope, but skeptical if something stand out I'll report.
/ quick connect couplers #7
I understand now.
Try a heat gun on the QD.
/ quick connect couplers #8
I'm a newbie & having a similar problem when I go to connect the two couplers for my 4in1... I swear myself blue in the face trying to get them to click home (10 minutes each) and then they miraculously decide to pop in as if there never was a problem.
Naturally there's an moderate amount of hydraulic fluid all over my hands & boots by this stage.
When I go to perform this evolution I've turned the tractor off & lowered the FEL after the fact. So, what am I doing wrong?
/ quick connect couplers #9
Ah HA! The answer is in a TBN thread from June of '09 "Hydraulic hoses are difficult to re-connect"!
So, if I read this right, with the tractor shut down & the FEL then lowered via the joystick, if I bleed a wee bit of fluid from the male end connector it should work.
Which makes sense regarding my previous statement about fluid being all over my hands & boots.
Thanks TBN contibutors! The power of 'search' has saved the day & stopped me from starting a thread for a subject already covered. :thumbsup:
/ quick connect couplers #10
Relieve the pressure before you disconnect your lines.
/ quick connect couplers #11
Gotcha!
So I went and did what no bloke should admit to... I got out my Operator's Manual & looked up "Connecting Implement Hydraulic Hoses". :ashamed: Sure enough, it says (with the engine stopped) to work my Dual Selective Control Valve Lever several times front-to-back and side-to-side to relieve pressure.
I hate it when that happens. :laughing:
YARD MULE (INOPERABLE) (A60736)
YARD MULE...
2016 Jeep Compass SUV (A61569)
2016 Jeep Compass...
2020 GMC AT4 CREW CAB TRUCK (A60430)
2020 GMC AT4 CREW...
2013 PRATT INDUSTRIES GARDNER DENVER TRIPLEX FRAC PUMP (A60736)
2013 PRATT...
2019 DRAGON ESP 150BBL ALUMINUM (A58214)
2019 DRAGON ESP...
2016 Chevrolet Silverado 1500 Single Cab Pickup Truck (A60352)
2016 Chevrolet...
