quick connect couplers
   / quick connect couplers #1
makinmulch
SE Texas
HydroAx PT-100G RC-100 with cimaf head X 3
Has anybody deleted there quick connects and hooked up the hoses from the mulcher straight to the tractor? I think it would help with flow. The quick connects always seem to be a pain one way or another.
   / quick connect couplers #2
It really is the correct way to run a mulcher but is messy and time consuming to change attachments . That's why people use them , I myself do it the hard way because flow is much better and they don't cope well with the amount of pressure my machine has .
   / quick connect couplers #3
Iron Horse is absolutely correct, that is the proper way. You will have faster recovery times and less heat buildup. Something you haven't considered is a quick couple can pop off spiking the hydraulic system and blowing the motor (case) seal. Seen this a time or two. And lastely all quick couple eventually leak unless they are the high dollar units, removing them is FREE.
   / quick connect couplers #4
I thought I read once that the couplers are oversized one size to counter this?
Spent half the day running around chasing another coupler today. I dont think the extra time it takes to remove the head, and plug the holes will add up to the time and money wasted on failed quick connects. Mulching is messy bussiness anyway. I'm hooking em up straight tomm.
   / quick connect couplers #7
After changing the shaft seal twice on my 148 because the quick connector loosened off two threads the P.O.S quick couplers are now in the garbage.
   / quick connect couplers #8
Yeah straight connect is the way to go. The big quick connects are hard to track down and are expensive!
2018 FREIGHTLINER M2 26FT NON CDL BOX TRUCK (A53426)
2018 FREIGHTLINER...
2016 Dodge Caravan (A51694)
2016 Dodge Caravan...
40ft Shipping Container (A52377)
40ft Shipping...
2009 Freightliner M2 106 MedTec Ambulance (A51692)
2009 Freightliner...
UNUSED HURRICANE STAND ON SKID STEER (A51247)
UNUSED HURRICANE...
