Snow Quick attach Snow plow for B series tractor
   / Quick attach Snow plow for B series tractor #1
torrin
Stanwood, MI
Kubota B2650HSDC
I have a B2650HSDC My back blade is messing up my gravel drive when the snow is too wet for my front mount Snowblower. I have a chance to purchase a used 60" quick attach snowplow blade but I need the piece that attaches to my quick attach underframe.
If you are not aware, on this tractor you cannot have the loader on when using the subframe. The V shaped connector from the BX series is smaller then the same piece for the B series. As I do over 3 miles of trails, the blade is not a complete winter option. The loader mounted blade can cause bent arms.
I am looking for the part number for that piece. I found the part number for the manual angle adapter. I want the part with the reinforced piece with the mount for the hydraulic cylinder.
All help appreciated.
   / Quick attach Snow plow for B series tractor #3
U can’t have the sub frame quick attach on and also have the fel attached. The sub frame also connects the mid pto to the blower or sweeper . Not sure if torrin wants to convert a skid steer qa to the sub frame qa?
Sorry if I did not make it clear, What I am looking for is the connecting sleeve with a for the hydraulic pivot system. The difference between the BX front mount Snowplow and the B series front mount snow plow the b series sleeve is 1+" wider, and 1/2" higher. The blades and the mount on the blade is the same. it is the connecting sleeve. Part Number I am looking for.
   / Quick attach Snow plow for B series tractor #5
When my gravel driveway is not frozen, I turn the back blade around 180° so that it does not dig in to the soft driveway. I've been doing this for 16 years and it's always worked just fine.
Joe
   / Quick attach Snow plow for B series tractor #6
Joe
There is your answer;front blade is not going to be any better if not frozen.
   / Quick attach Snow plow for B series tractor #9
This winter: .00000002 inch. But snow drifted bad, in a few places.
We are glad it is Spring.
Thank you for all the responses. I took the Part called the female hitch off of the BX2763A Front blade, and it fits my Quick attach, So I don't need the B size hitch
Your responses appreciated.
PALLET OF PORTABLE AC UNITS (A57192)
PALLET OF PORTABLE...
2012 Mazada 3 Sedan (A55853)
2012 Mazada 3...
Trail King 20ft T/A Flatbed Equipment Trailer (A51691)
Trail King 20ft...
(2) 5' FOLD UP TRAILER RAMPS (A57192)
(2) 5' FOLD UP...
2019 MDB FM180 FINISHING MOWER (A51247)
2019 MDB FM180...
2018  FREIGHTLINER M2 26FT NON CDL BOX TRUCK (A52576)
2018 FREIGHTLINER...
