Quick attach question
   / Quick attach question #11
I have the same tractor and mine is reverse. Mine stays in the unlock position but works loose (not in the full lock positon) with implements on. The pins stay in the mounts but the lever flops. I didn't really see much adjustment so I just hold it in position with a tarp tie down. I'll keep an eye on the thread!
Don't you think it is a little ridiculous to use a tarp tie down on a 20K plus machine?:D
I don't have any grease fittings on the pins. Maybe just try and clean them up and apply some grease to the pins. After you grease the pins up they will be full of dirt again in a short time.:eek:
I personally think something is wrong. Any input from dealers yet?
   / Quick attach question #13
Donny, look and see if you could install a grease fitting. Ours go in from either side. Greasing regularly forces the dirt out. The NH skidsteer engineered arrangement is very slick. When you lock the arms down, you feel a confident postive lock. I always do the check for the through pins, and a visual check also. Then off to the "races".
   / Quick attach question #14
I don't think grease is the issue. The pins and the linkage move very freely up to the point where the plates need to slide to the outside. One of these plates will move if pushed but the other will not slide sideways at all and that prevents the first plate from moving on it's own. That in turn keeps the linkage from locking in the pins up position.
   / Quick attach question #15
Maybe this calls for a dry graphite lubricant like.....'slip plate'.
http://www.superiorgraphite.com/products/index.php?id_ctg=119
TSC stocks it in spray and brush on....
Don
Maybe the tractor should come with a bungee cord installed option.:eek:
   / Quick attach question #18
Donnyj said:
Mine just has a single lever in the center that works both sides. Thanks anyway.
Must be a differant setup than on my DK 35 . I have the 2 lever skid steer type QA. ( No problems with it.. Works good).
   / Quick attach question #19
I did lube it and it worsened!
I just look at it as a safety device ............... :)
I took some pictures of the quick attach setup on my 45S. I took pictures in the locked and unlocked positions. Looking at it up close, my opinion is the 2 springs {one on each side} are not strong enough to keep the latch locked in the unlocked position. You can see some wear on the sliding mechanism. The springs look like they should keep the sliding mechanism in the unlocked position by applying upward pressure. Anybody else have any opinions about it?
LOT: Assortment of Opened Oil, Coolant, Parts Wash, Hydraulic Oil (A59076)
LOT: Assortment of...
2013 CATERPILLAR 336E L (A58214)
2013 CATERPILLAR...
2003 TRAVIS BODY & TRAILER ALUMINUM BELLY DUMP (A58214)
2003 TRAVIS BODY &...
1995 NEWTON CROUCH PULL SPREADER (A58375)
1995 NEWTON CROUCH...
2017 Bobcat T450 Compact Track Loader Skid Steer (A56857)
2017 Bobcat T450...
2021 Deere 333G (A53317)
2021 Deere 333G...
