Quick Attach option
   / Quick Attach option #11
I can't think of what I'd ever use it for
Yeah that's what I thought too .... oops. Get it - don't regret not getting it like I do now.
   / Quick Attach option #12
The world of attachments will be a lot more useful with the quick attach on your FEL.
I use a general purpose bucket with teeth, a high capacity bucket, a sifting bucket, a hydraulic auger, forks, a blade, and a scarifier with my quick attach. I change attachments so often that I am looking at getting a hydraulic attachment plate so I can change the attachments with just a push of a button.
Eric
   / Quick Attach option #13
</font><font color="blue" class="small">( I am looking at getting a hydraulic attachment plate so I can change the attachments with just a push of a button )</font>
You know, I've thought this must exist in the tractor world....
Please share details (cost, wiring, what you have to replace, etc.)
Thanks,
Mark
   / Quick Attach option #14
<font color="blue"> ( I am looking at getting a hydraulic attachment plate so I can change the attachments with just a push of a button )
Thanks,
Mark</font>
Mark,
Bobcat has had this on there skid steers for many years. I believe they call it the Bob-Tach. I was recently at the big Cat dealer in Portland Oregon and saw that Cat has this same thing available for their skid steers also. All it is is two small hydraulic cylinders that when actuated by an electrically operated hydraulic valve drive down shafts locking the bucket in. I have not seen this on a tractor yet. Since the new tractor quick attaches use the same universal attachment mechanism there is no reason why a tractor couldn’t use the same system.
So here is something for you entrepreneurs and inventers out there. Come up the mod. Advertise it on TBN and make your fortune. Otherwise us build it yourself guys will just have to come up with it on our own. It looked really easy.
This week I am invited to the local CAT dealers open house/barbeque. I’ll try and get more cost info then. Maybe I should take a camera?
Later Eric
   / Quick Attach option #15
</font><font color="blue" class="small">( there is no reason why a tractor couldn’t use the same system)</font>
I agree. I was thinking of some sort of electrically-driven pin, but hydraulic would be cool too.
</font><font color="blue" class="small">( Maybe I should take a camera? )</font>
That would be great! Enjoy the bar-b-q!
Mark
   / Quick Attach option #16
Guys,
I don't think this would help much on a tractor. On a bobcat I can look right down and see that the bucket or other implement is lined up right and then use the electronics/hydraulics to lock it in place. Your right there and have a great view of the bucket attachment.
But at least on my tractor the hood is in the way. I usually need to get off the tractor and make sure its lined up correctly.
I then flip the levers while I am off.
Fred
   / Quick Attach option #17
</font><font color="blue" class="small">( the hood is in the way )</font>
I have to say that this is one of the best things about the "Boomer" line.
With the sloping hood design, I can look right down and see everything when I am driving into my attachments, the Only reason I do get off the tractor is to lock the pins down.
   / Quick Attach option #18
</font><font color="blue" class="small">( I have to say that this is one of the best things about the "Boomer" line.
With the sloping hood design, I can look right down and see everything when I am driving into my attachments)</font>
My tractor does not have the sloping hood design
But I can easily see everything when driving into attachments from the driver seat.
   / Quick Attach option #19
All u really need to see is the top outside corners so the top hooks in, when u lift it the bottom will fall right in place.
Only problem on most SSL is when u get hi-flow hydraulics u can't get the hydraulic locks. /forums/images/graemlins/frown.gif
Some place I saw a kit to add the power locks and it used 1 cylinder in the middle.
   / Quick Attach option #20
Fred,
You are correct about checking the alignment. However most the time if the attachment is clean and the adaptor is clean you can just hook under the lip, jiggle it a little to make sure it's seated and lock the pins. I think it would be nice.
Eric
2014 CATERPILLAR D6T XL CRAWLER DOZER (A52709)
2014 CATERPILLAR...
2006 Mercedes-Benz (A55758)
2006 Mercedes-Benz...
2012 MACK CHU613 DAYCAB (INOPERABLE) (A58214)
2012 MACK CHU613...
(INOP) YAMAHA GAS GOLF CART (A58374)
(INOP) YAMAHA GAS...
2015 New Holland T4.95 MFWD Cab Tractor (A55314)
2015 New Holland...
Swict 66" Bucket (A57149)
Swict 66" Bucket...
