Quick Attach mystery on Dk45sehst
   / Quick Attach mystery on Dk45sehst #11
I had an interesting thing happen with my quick attach on my Kioti the other day. I was working on digging up some stump and a big root came up between the bucket and the loader arm crossbar and hit the release handle just right to open it up and dislodge the bucket. Couldn't do it again if I tried
   / Quick Attach mystery on Dk45sehst #12
I had an interesting thing happen with my quick attach on my Kioti the other day. I was working on digging up some stump and a big root came up between the bucket and the loader arm crossbar and hit the release handle just right to open it up. couldn't do it again if I tried
You might not be able to do it again if you try but it will happen again sometime if you are rooting around in brush. I welded a little loop on the tip of the lock handle and then use a sturdy trucker's solid bungee to hold it in place (loop around the tube under the handle then back to the welded loop. You can also drill a hole in the handle tip as MotorSeven did.
   / Quick Attach mystery on Dk45sehst #13
I ahve to do some stump removal the weekend. I think you should bring up your root grapple and give it to me. :) I'll definitely look into doing something to keep it from happening again. Thanks.
   / Quick Attach mystery on Dk45sehst #14
   / Quick Attach mystery on Dk45sehst #15
I haven't done that myself, but have heard a couple of folks doing the same thing when using the grapple.
1982 SHOP BUILT GOOSENECK 24 FT TRAILER (A58214)
1982 SHOP BUILT...
TANK MANIFOLD (A55745)
MARATHON 20KW GENERATOR (A58214)
MARATHON 20KW...
JMR MINI GRAPPLE (A56857)
JMR MINI GRAPPLE...
2026 Quality steel dump truck (A56859)
2026 Quality steel...
2019 Ford F-350 4x4 Flatbed Truck (A55788)
2019 Ford F-350...
