Quick attach fit
/ Quick attach fit #1
kevinj
West MI
BX-1860, L3940HSTC, B7500, Farmall M, Farmall 560D
I have searched the forums but cannot find the thread about shimming skid steer attachments. I have a Markham grubber that fits a bit too loose while everything else fits fine. I would rather shim it than ship it back. I see several ways to shim it but would like to review what others have done, so if someone can tell me which thread that was I would appreciate it.
/ Quick attach fit
Bump to the top, anybody remember the thread?????
Thanks in advance
/ Quick attach fit #3
Thanks in advance
Try a search with: skid steer shim
There are 2 other matches besides this thread.
Good Luck
Kurt
/ Quick attach fit
/ Quick attach fit
I bumped this thread. There is a picture of a Phirana device made exactly like the Markham and you can see how the rebated edge sits too low at the top wedge area. I will put up some pics when I get time to make the repair. I have talked to Markham and Allen is going to look at a Kubota mount to see if he can solve the issue with future manufacturing. Thanks again for the the link, it confirms my diagnosis on the this issue. I also would like to say that all my attachments with a soilid plate fit fine. The only issue is with a partial plate attachment.
http://www.tractorbynet.com/forums/kubota-owning-operating/95142-kubota-skid-steer-qa-question.html
/ Quick attach fit #8
Hi Kevin,
I have the Kubota QA mount and Markham Grubber bucket, also. The bucket fits just fine and I have not had any problems with the fit. My Kubota is new (2006), and I had read somewhere in these forums that Kubota had some pin issues in the earlier QA mounts. Maybe it is in the QA?
/ Quick attach fit
Redbug said:
Hi Kevin,
My tractor is new also. Do you have good solid spring pressure on your lock pins? My bucket fits and works OK but it is not right. The QA fits the bucket and forks fine. If you look at the link I posted the one pic of the grapple shows the QA arm and the rebated top which is what I have.
http://www.tractorbynet.com/forums/...r-qa-question-ksm-kubota-pirranha-grapple.jpg
/ Quick attach fit #10
Kevin,
I do have spring pressure on the pins. I can see the springs compress about 1/2" when I lock the handles down. Any slop in the bucket attachment is all taken up by the wedge shaped pin as it is locked. I would first check to make sure you have enough spring pressure to jam the wedge shaped pins into lower end of the bucket when you turn the QA lever to lock it down. It may not be enough.
I also looked at your picture and mine is like yours...with the rebated type top. It's odd that the same QA does not perform equally. Also, the thread you attached about the "Kubota Skid Steer QA Question", was the one I had remembered.
Also, on my Grubber Bucket, I took an angle grinder and sharpened up the edge on the top of the bucket, (the first foot or so). It made a difference in cutting roots, etc.
/ Quick attach fit
Redbug said:
Kevin,
The first two pics show the poor fit with excess clearance at the bottom. The second two show the fit with a plate to get contact below the rebated top and all fits fine. It appears that the Kubota unit needs to have a full plate mount and not partial rails like some use.
/ Quick attach fit
And one more showing the bucket construction and void area on the mount surface.
1453 (A57192)
1453 (A57192)
2016 Ford F-350 Pickup Truck (A61568)
2016 Ford F-350...
17601CFL (A59228)
17601CFL (A59228)
UNKNOWN  20 FLATBED GOOSENECK (A58216)
UNKNOWN 20...
2016 Ford Explorer (A59231)
2016 Ford Explorer...
2022 East Manufacturing 48ft. T/A Walking Floor Trailer (A61568)
2022 East...
