Quick attach adapter
/ Quick attach adapter #1
scappoose
Scappoose, Oregon
mahindra 2816/FEL
I am thinking having the quick attach option for the loader. Has anyone had any problems with theirs'?
At my home I have no total flat place, Just dirt, unless I pour a slab, it seems that a quick attach would be cheaper and more useful. Any know of a after market quick attach adapter for a Kubota?
At what temperature do Kubota engines start having problems starting? When I asked the dealer, He said the the glow plugs took care of the problem.
/ Quick attach adapter #2
The low range for diesel engines is about 40-45 deg. F., colder and you need glow plugs.
/ Quick attach adapter #3
My L4400's loader is quick attach. I drop it frequently. Many times its dropped on unlevel dirt. I look for the best spot I can find. It never takes me more than a couple minutes to get it re-attached. After you do it a few times it becomes easy. Definitely not worth pouring a slab of concrete for that purpose alone.
Sorry, can't help you with the starting issue, my tractors are spoiled in a heated shop.
/ Quick attach adapter #4
I may be misunderstanding you, but pretty much all Kubotas made within the last few years have easily dismount/mount FEL's. As mentioned, concrete is preferable, but I often use crushed rock or dirt if the dirt is firm or use boards if it is not. We have a BX2660, L5030 and M8540 and all the FEL's are easy to dismount/mount.
/ Quick attach adapter #5
Not sure what you mean by quick attach? If you mean a skid steer type Q/A, it would depend on the model Kubota FEL that you have. When I owned a Kubota B3030 I had an ATI -Tach-All Q/A. My current GL3240 has the factory Kubota Q/A on it. They are very worth while if you have a FEL with enough lift capacity. Swapping bucket, to fork or grapple etc is a minute or less with a Q/A.
I use glow plugs for starting at all times. A block heater helps in the winter months to prewarm the engine and prevent wear as does synthetic engine oil.
2022 Case CX220E Hydraulic Excavator (A61572)
2022 Case CX220E...
Caterpillar RM-350/RM-350B/SM-350 Reclaimer Mixer Service Manuals (A63117)
Caterpillar...
PULL TYPE DIRT PAN (A63291)
PULL TYPE DIRT PAN...
Like New! Kubota L2501 HST Tractor Package – LA525 Loader, RCR1260 Cutter
Like New! Kubota...
Caterpillar 214-214B Service Manuals for Excavators (A63117)
Caterpillar...
2000 CATERPILLAR 988F SERIES II WHEEL LOADER (A64279)
2000 CATERPILLAR...
