Quick attach adapter
   / Quick attach adapter #1
scappoose
Scappoose, Oregon
mahindra 2816/FEL
I am thinking having the quick attach option for the loader. Has anyone had any problems with theirs'?
At my home I have no total flat place, Just dirt, unless I pour a slab, it seems that a quick attach would be cheaper and more useful. Any know of a after market quick attach adapter for a Kubota?
At what temperature do Kubota engines start having problems starting? When I asked the dealer, He said the the glow plugs took care of the problem.
   / Quick attach adapter #2
The low range for diesel engines is about 40-45 deg. F., colder and you need glow plugs.
   / Quick attach adapter #3
My L4400's loader is quick attach. I drop it frequently. Many times its dropped on unlevel dirt. I look for the best spot I can find. It never takes me more than a couple minutes to get it re-attached. After you do it a few times it becomes easy. Definitely not worth pouring a slab of concrete for that purpose alone.
Sorry, can't help you with the starting issue, my tractors are spoiled in a heated shop.
   / Quick attach adapter #4
I may be misunderstanding you, but pretty much all Kubotas made within the last few years have easily dismount/mount FEL's. As mentioned, concrete is preferable, but I often use crushed rock or dirt if the dirt is firm or use boards if it is not. We have a BX2660, L5030 and M8540 and all the FEL's are easy to dismount/mount.
   / Quick attach adapter #5
Not sure what you mean by quick attach? If you mean a skid steer type Q/A, it would depend on the model Kubota FEL that you have. When I owned a Kubota B3030 I had an ATI -Tach-All Q/A. My current GL3240 has the factory Kubota Q/A on it. They are very worth while if you have a FEL with enough lift capacity. Swapping bucket, to fork or grapple etc is a minute or less with a Q/A.
I use glow plugs for starting at all times. A block heater helps in the winter months to prewarm the engine and prevent wear as does synthetic engine oil.
WE DO NOT GUARENTEE HOURS UNLESS WE SAY SO!!! (A50775)
WE DO NOT...
Grove 4x4 Rough Terrain Hydraulic Crane (A51691)
Grove 4x4 Rough...
2020 CHEVROLET Z71 TEXAS EDITION TRUCK (A51406)
2020 CHEVROLET Z71...
Redirective Crash Cushion Guardrail (A51692)
Redirective Crash...
Year: 2014 Make: Ford Model: Taurus Vehicle Type: Passenger Car Mileage: Plate: Body Type: 4 Door (A51694)
Year: 2014 Make...
2000 FORD F450 SUPER DUTY SINGLE CAB FLATBED TRUCK (A51406)
2000 FORD F450...
